    door latch rebuild kit
    Number of posts : 387
    door latch rebuild kit Empty door latch rebuild kit
    Post by whopman Thu Oct 21, 2010 6:51 am
    Looking for a driver and passenger door latch rebuild kit. The shaft on mine is worn and the return spring is broken.
    Anyone know where you can find one?
    Number of posts : 1778
    door latch rebuild kit Empty Re: door latch rebuild kit
    Post by m1dadio Thu Oct 21, 2010 7:46 am
    No kits I ever heard of, Which door latch do you need?
    I have both front door latches if you need one.
    M1D
    Post by whopman Thu Oct 21, 2010 8:26 am
    M1 its the door latch relay mechanism that the inside door handle attaches to. I have one on the 65 but don't want to strip parts off it. I thought I saw a picture of one in one of the forums. From napa ????
    Number of posts : 1383
    Post by BILLS66 Thu Oct 21, 2010 5:08 pm
    whopman,you can get new ones that fits a 64 thru 66 chev pu ,all you have to do is remove the bar (it's the wrong size)and rivet on your old one to the new part. and they are cheap about $20. Bill
    Post by whopman Fri Oct 22, 2010 3:09 am
    Thanks Bill...ordering them...how about the window regulator ones do they make a repair one for that or do we use the 64-66 truck ones as well and modify.
    Post by BILLS66 Fri Oct 22, 2010 6:51 am
    No go on the window regulator even tried to modify one .Get ahold of macsdoghouse on vcvc he rebuilds them. Bill
      Current date/time is Thu May 16, 2024 7:23 pm
