    Tie Rod Ends
    Number of posts : 823
    Tie Rod Ends Empty Tie Rod Ends
    Post by mbasaraba Tue Nov 13, 2012 5:06 am
    There was a topic that was being discussed on what tie rod ends to use and also an adjustable steering linkage and the use of tie rod ends on that but I cant seem to find it. I have been searching for 2 days. Anyone have that thread bookmarked or know what tie rod ends to use for both of them?
    Thanks,
    Rakehell
    Number of posts : 9
    Registration date : 2011-01-10
    Tie Rod Ends Empty Sterring linkage
    Post by Rakehell Tue Nov 13, 2012 7:13 am
    The part # is for a second gen. chevy van.Tie rod adjusting sleeve.....ES2004S.....The Tie rod end is..... ES409L.....The Threaded rod is .....7180035.....All of the parts #s are from .....NAPA.....And i don't know if they will work on a first gen. chevy van. This info. is to build the sterring linkage from the sterring knuckle to the pitman arm.You should check with Donivan65 and M1dadio.....They can get you all the info that you may need
      Current date/time is Sun May 12, 2024 5:29 am
