What is the easiest way to remove the rad from an a100p/u?
thx v-v's
thx v-v's
RodStRace wrote:Drain coolant and remove the hoses.
Remove belly pan.
Disconnect trans cooler lines, if equipped.
Raise and support front of van.
Remove upper bolts first.
Support radiator and remove lower bolts.
Remove radiator out the bottom.
If there is a fan shroud, remove it.
