scarlin
gearheadflicks
    The little hangy down thing
    gearheadflicks
    gearheadflicks
    Number of posts : 32
    Registration date : 2012-04-19
    The little hangy down thing Empty The little hangy down thing
    Post by gearheadflicks Wed Oct 10, 2012 11:51 pm
    ha ha ok... so what is that 1" tube/pipe that hangs down from the engine dripping and smoking oil?
    can I extend it to get it away from the front area?
    The little hangy down thing Empty Re: The little hangy down thing
    Post by Twinpilot001 Thu Oct 11, 2012 5:50 am
    [iYes u can extend the tube -also =can run a rubber hose to anywhere you want it to exit.
    scarlin
    scarlin
    Number of posts : 258
    Post by scarlin Thu Oct 11, 2012 1:38 pm
    KIDS, lol. It's called a road draft tube. Used on cars and trucks before the first emission stuff started mid 60's. It ventilates the crankshaft fumes. Wherever you put the tube extension make sure it will suck the fumes out.
    Do not let the Feds see it.
    Number of posts : 394
    Post by dan nachel Thu Oct 11, 2012 4:00 pm
    You can run a rubber hose from that tube to a plastic bottle. fill the bottle with cotton balls and cut vent holes in the bottle. The engine will breathe without marking its territory. You will need to replace the cotton from time to time.
    The little hangy down thing Empty feds?? haha
    Post by Twinpilot001 Thu Oct 11, 2012 5:24 pm
    [ifeds cant do a thing =the old grandfather rule applys - was origionally called a Crankcase breather tube - kind like a Harley -markes its territory.!!
    Number of posts : 3046
    Post by RodStRace Thu Oct 11, 2012 6:33 pm
    dan nachel wrote:You can run a rubber hose from that tube to a plastic bottle. fill the bottle with cotton balls and cut vent holes in the bottle. The engine will breathe without marking its territory. You will need to replace the cotton from time to time.
    I don't know how well that will work. At idle, it's true it's just sitting there puffing away. However, at speed, it does create a flow thru effect (road draft) that pulls air from the crankcase. Kind of how a burrowing animal's den has flow. If you plug it or keep it from pulling air, it will allow the crankcase to pressurize, blowing the seals.
    The mfger's made those tubes long and pointed down not only to keep the grime off the top, but also to take advantage of the effect.
    http://en.wikipedia.org/wiki/Crankcase_ventilation_system
    gearheadflicks
    gearheadflicks
    Post by gearheadflicks Thu Oct 11, 2012 7:01 pm
    now i know what that hangy down thing is. Smile
    thanks guys!
    Post by RodStRace Thu Oct 11, 2012 7:25 pm
    Just so long as you aren't taking about your "special purpose"...
    The little hangy down thing The-jerk-hd-dvd-20070518110047977-000
    OldSkoolVannin
    OldSkoolVannin
    Number of posts : 51
    Registration date : 2011-11-19
    Post by OldSkoolVannin Sat Oct 13, 2012 4:28 am
    Check this out, I installed a PCV valve and it has really helped. You need a replacement valve cover with the hole and baffle for the PCV. I got it on eBay for about $40. Then 2' of hose hose to the NPT port at the base of the Carburator base plate. And seal up the little hangy down thing.
    https://vintage-vans.forumotion.com/t26791-putting-a-pvc-valve-in-a-170
    Good luck
    grpphoto
    grpphoto
    Number of posts : 14
    Registration date : 2012-07-03
    Post by grpphoto Tue Jan 15, 2013 8:40 pm
    gearheadflicks wrote:ha ha ok... so what is that 1" tube/pipe that hangs down from the engine dripping and smoking oil?
    No. The end is cut at an angle and extends into the airflow. When the vehicle is moving at anything over about 30 mph, it creates a vacuum in the tube. That vacuum pulls air into the oil filler cap (called a "breather cap" on these old guys) and through the engine. This is the crankcase ventilation of the era.
    If you modify this thing at all, you will pretty much destroy the ventilation system in your engine. That's fine if you drive maybe 1,000 miles a year and change the oil several times a year. If you're into the 3,000 mile oil change, don't do it.
    George in NJ
      Current date/time is Sun May 19, 2024 6:06 am
