Will a 6 cylinder engine shroud fit a v-8 engine?
Fan shroud question...
Re: Fan shroud question...
Yes.
- Number of posts : 8731
Rod are you sure of that,??? when i swaped out my /6 for a v8 a noticed the shroud was not centered so i never even tryed it. ?????
Yes, I went through my parts and vans and figured it out to answer another post.
Here are the pictures. If someone has a different ORIGINAL fan shroud, please post it.
slant six shroud
V8 shroud
V8 installed view
slant six shroud
V8 shroud
V8 installed view
http://www.ebay.com/itm/150917084791?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
The reason I asked the original question, "Will a 6 cylinder engine shroud fit a v-8 engine"? Is because I saw this shroud (above), listed on Ebay. He says that it will fit both 6 & 8 cyclinder engines.
If you notice, the photos of the Ebay shroud (above), it does not look exactly like the photo listed by "RodStRace".
Well, that IS different! The opening IS shifted over to the left and up. That makes sense on a /6.
Maybe the ones I gathered have been swapped out over the years.
I have the 108 /6 and a parts /6. The 108 did not have one and the parts van had the shroud loose inside. Does anyone have another /6 with an intact installed shroud? Pictures of the right side and/or the bottom would be a big help in solving this.
The 1964 Dodge PU in studio city for sale has a photobucket link. In there was this picture of a /6 fan shroud. It shows the bottom section NOT cut into, like the Ebay one.
So... would I be wrong to assume that the fan hole for the V-8, should be centered and the hole for the 6 cylinder should be offset to one side. If that is correct, the Ebay shroud is not for a V-8. Do all of you agree?
west coast yes i do agree
Many thanks, for your info.
West coast, the V8 one is offset, but the /6 is offset more.
Both have offset that hangs over left side bracket.
The /6 opening is a couple inches from right side, does not go into bottom angle.
The V8 opening is flush with right side and cuts into bottom angle.
From inside, the right side will be the spot to check. From underneath, the center and if the opening is above or into the angled bottom is the spot to check.
West coast, I'm sure glad you found this. I was going to install the shroud on the 108, but decided that since it didn't overheat and it was so much effort, I didn't need to. That would have been a major bummer to pull it all apart and then find it wouldn't fit!
thanks rod I would have never guessed the shroud on the v-8 would have any off set. i built my own from a mid 70's dodge pick up.. but I also have a after market rad as well....
westcoastvanner, that's the slant 6 one you posted that is backed up by the slant 6 shroud installed the 64 PU.
v8 shrouds are different in that the one for the six the fan is offset to the left a bitdix wrote:Rod are you sure of that,??? when i swaped out my /6 for a v8 a noticed the shroud was not centered so i never even tryed it. ?????
Rod =Knows his dodge vans & stuff! believe him on that stuff! Me=? I only know what i was susposed to do today! Forgot -yesterday alredy!!
