Could anyone let me know if the 68 A,s with a 318 came stock with factory fan shrouds on the rads,and if you have a pic that would be coool because mine isn,t.
Cheers
Cheers
roll-in bad neighbourhood wrote:Could anyone let me know if the 68 A,s with a 318 came stock with factory fan shrouds on the rads,and if you have a pic that would be coool because mine isn,t.
Cheers
Thanks for the replies. I've been up north working and had no internet,Blackace is your shroud factory equipment,i will pm born2late and see if his is similar.Did you notice any difference in cooling, with the clutch fan vs the flex fan.dix wrote:the / 6 shroud is off center... the 318 shroud would be on center.
RodStRace wrote:In the Mopar world, the 'right way' is to run a clutch fan and a shroud or a solid fan with a shroud.
High HP and long haul vehicles came with the clutch fans. Low buck and short trip stuff like our vans and the trucks tended toward the solid fans. Many of them did not have shrouds but every van I've seen had provisions for them. They probably got left off at some point. These things need all the airflow help they can get!
If you upgrade your van for more modern fast-paced driving and road trips, I'd suggest a clutch fan.
Shrouds should bolt on to the back, and extend out away from the radiator core around the edges as much as possible to limit blocking the air flow. The fan edges should be 1/3 to 1/2 way into the opening. There should be enough gap to allow the fan to be unbolted, tilted and removed.
Flex fans are an aftermarket mess that tend to disentegrate.
Don that would be great if you could have a look for me.pittsdriver wrote:I might have an extra shroud. If I have one I'll let you know. Don
roll-in bad neighbourhood wrote:Thanks for the replies. I've been up north working and had no internet,Blackace is your shroud factory equipment,i will pm born2late and see if his is similar.Did you notice any difference in cooling, with the clutch fan vs the flex fan.dix wrote:the / 6 shroud is off center... the 318 shroud would be on center.
