anyone have problems with there windshield, i think its the plastic between the glass, it has scratches that you cant feal, i buffed both sides and its still there, any fixing it? or do i replace the windshield?
windshield
Re: windshield
Flat glass. Laminated. Most glass shops should be able to duplicate the pattern. Looks like you have a nice ride, so you may consider the blue band on the top.
FYI - Walker eliminated the gasket (back beaded with typical urethane instead) and butt glazed his with some clear silicone at the seam. Looks real good + you don't have to buy the gasket if it's dry and cracking up.
Re: windshield
thanks alot, i'll check on that blue band at the top when i find someone to make it,
- Number of posts : 8731
Re: windshield
I had mine made using 20 percent tinted i'm real happy with that..
Re: windshield
were did you get yours dix? i'm close to pittsburgh
