    67 GMC 4X4 conversion ?
    scottanchee
    scottanchee
    Number of posts : 2
    Registration date : 2012-08-01
    67 GMC 4X4 conversion ? Empty 67 GMC 4X4 conversion ?
    Post by scottanchee Wed Aug 01, 2012 11:11 am
    I am in the process of buying a 67 GMC 6 cyl 3 spd Van with 4X4
    67 GMC 4X4 conversion ? DeviceMemoryhomeuserpicturesIMG00179
    Here is a pic of the T case shifter behind the dog house
    67 GMC 4X4 conversion ? DeviceMemoryhomeuserpicturesIMG00168
    6 bolt rims and man locking hubs running D 44 front and rear ends with 307 gears
    Anyone ever hear of a factory 4X4 67 van ?
    Number of posts : 1868
    67 GMC 4X4 conversion ? Empty Re: 67 GMC 4X4 conversion ?
    Post by HandiVanMan Wed Aug 01, 2012 12:04 pm
    Welcome to Vintage-Vans!!! GM did not produce any of the 1st or 2nd gen vans equipped with 4 wheel drive.
    scottanchee
    scottanchee
    Number of posts : 2
    Post by scottanchee Wed Aug 01, 2012 12:41 pm
    OK thanks
    It needs a rocker on the driver side and it needs fixing around the filler neck outside and inside . Is there a place that sells these body panels ?
    Will a small block fit in place of the I6 ?
    Any direct links would be much appreciated
    Post by HandiVanMan Wed Aug 01, 2012 12:54 pm
    There is a link on the home page for rust repair panels. Yes a small block will work but you will need a V8 radiator,Fan shroud, Expansion tank, V8 radiator mounting brackets & I think V8 motor mounts. There is a member here that has all of those parts for the V8 swap for sale $250
    Number of posts : 655
    Post by vanner68 Sun Aug 05, 2012 12:15 pm
    Just FYI, those are probably full size Blazer axles, in case you need to source parts.
    COMSTOCK_108
    COMSTOCK_108
    Number of posts : 16
    Registration date : 2012-03-10
    Post by COMSTOCK_108 Sun Aug 05, 2012 12:56 pm
    I have all the parts you need.
    See previous post for a list.
    comstock_108
    r.b.prince@att.net
      Current date/time is Fri May 17, 2024 3:54 am
