+5
9 posters
    Engine Knock
    Number of posts : 361
    Engine Knock - Page 2 Empty Re: Engine Knock
    Post by ScottyJones Mon Jul 30, 2012 7:46 pm
    Oh a REAL motorcycle shop eh? Must be GP? Will do.
    So, I slid the torque converter back and the noise wasn't there like it was in the video above. Is there something that would make the knock only happen when the engine is warmed up though?
    Removed the valve cover, everything looks to be normal in there, but then again Im not 100% sure what exactly to look for.
    Post by Digz Mon Jul 30, 2012 7:54 pm
    M1 mentioned the flex plate to crank bolts, I have a van here where one of the previous owners thot maybe it had a rod going, The flex plate/crank bolts were slopped out and was letting the thing move around on the crankshaft. Check for movement (by hand) between the crankshaft and flex plate. Sometimes they can even be cracked and that would be harder to tell without dropping the trans.
    Post by donivan65 Mon Jul 30, 2012 8:35 pm
    So are you saying that when you disconnected the torque convertor from the flex plate the noise went away? So grab that flexplate and see if it is loose in any way,,,,,,,also pry the flexplate forward and back to check if the crankshaft is moving up and back,,,,,,,, However,,,that torque convertor could be falling apart inside or expanding when the fluid gets hot,,,look for scraping or rubbing spots all over the torque convertor,,,,,,
    Post by ScottyJones Tue Jul 31, 2012 10:10 am
    Im going to check it out down there some more today or tomorrow. Could a worn out torque converter also explain some of the driving problems I was having before? sluggishness etc?
    Post by Twinpilot001 Tue Jul 31, 2012 10:37 am
    possibly cracked flexplate @ crank bolts area
    Post by donivan65 Tue Jul 31, 2012 12:47 pm
    Spin that torque convertor by hand and see if it is clunky,,,,,,,,,
    Post by ScottyJones Wed Aug 01, 2012 10:03 am
    So, no visible wear on the torque converter and I can't hear anything unusual when I spin it by hand. Flexplate has no play when I try to move it back and forth by hand.
    Tried starting the motor with the torque converter slid back again. Don't know if this means anything, but it's harder to start than normal. Then after it was running for a few seconds, I heard a nasty sounding grinding noise so I quickly shut it off.
    Maybe we can get together this weekend after your 1/2 price ecology sale, Don?
    Post by donivan65 Wed Aug 01, 2012 10:57 am
    Did the torque convertor slide forward and hit the spinning flexplate? tie it back into the transmission the best you can and see if the noise is still there,,,,,the torque convertor could only be getting noisy once it starts working hard to turn the trans,,,,
    Post by donivan65 Wed Aug 01, 2012 5:13 pm
    Well Scott,,,,, IF,,,,you got a NEW noise,,,disconnect the power from the distributer and crank the engine,,,,if you hear banging with that torque convertor hooked up or unhooked,,,,(not hitting the flexplate),,,,you are done for,,,,,do a compression test or at least hold you finger over the spark plug holes and feel if any air comes out as you crank the engine,,,,rod knocks don't have a happy ending,,,the bearing could spin and the rod can break off the crankshaft,,,so you are looking to find a piston not going up and down and if you do,,,,it's over,,,,,,,,,,
    Post by ScottyJones Wed Aug 01, 2012 8:28 pm
    Ran out of light before I could pull the plugs and do a compression test, but here's what happened.
    Pulled that torque converter back and secured it with some wire. Van started up and ran fine…noise wasnt there like before
    But then after about 5 minutes of idling the knocking slowly came back! So, it seems to only be happening when the motor is warmed up.
    Mad
    Post by donivan65 Wed Aug 01, 2012 10:37 pm
    The only thing we are concerned with is if the noise is there with the torque convertor disconnected,,,,and you say it is,,,,,and it gets worst the hotter the engine gets,,,,,do you have an oil pressure gauge to see what the pressure is, and gets, as the engine gets hotter,,,,Maybe Autozone will let you use one for free,,,,,we just need as much evidence as we can get before you bite the big one,,,,but if you have engine noise, nothing you can do about it,,,,the damage is done,,,,the noise will probably stop when the connecting rod breaks and comes out the side of the engine,,,,
    Post by donivan65 Thu Aug 02, 2012 12:04 am
    I dug my old engine out thats been sitting in a shed for 15 years and pulled the head off it,,,,,still looks good, spins over easy,,,,so I guess we could pull yours out and put this one in for awhile until you get yours rebuilt or find another one,,,,
    Engine Knock - Page 2 Repai306
    Engine Knock - Page 2 Repai308
    thatcherworks
    thatcherworks
    Number of posts : 102
    Registration date : 2012-07-14
    Post by thatcherworks Thu Aug 02, 2012 12:07 am
    nice use of a lawnmower!
    Post by donivan65 Thu Aug 02, 2012 12:22 am
    It's a tough life for anything with wheels at my place,,,,,,,,one of my car dollys is under the old 250 engine in Devimaus garage right now,,,,
    Engine Knock - Page 2 Tree_917
    Engine Knock - Page 2 Tree_113
    Post by ScottyJones Thu Aug 02, 2012 8:18 am
    Don, that would be so great! I am going to call around and price out a rebuild vs. a remanufactured motor. If it's not too much more, I may just go ahead and put a new motor in. If a rebuild looks more reasonable, then let's throw your old motor in in the meantime.
    Post by donivan65 Thu Aug 02, 2012 8:50 am
    Make a plan,,,,I will come pull that engine out and take it to a machine shop or put my or another engine in it,,,,You need to get it ready for the van show on August 29th,,,,I don't want to deprive the people from seeing how you upper class Sportvans live,,,,
    Post by ScottyJones Thu Aug 02, 2012 11:49 am
    I will have a plan by the weekend!
    Post by donivan65 Thu Aug 02, 2012 1:31 pm
    ,,,,,,is the plan a For Sale sign?
    Post by ScottyJones Thu Aug 02, 2012 1:53 pm
    hahaha, I'm not ready to give up just yet. I'm in this for the long haul….pun intended.
    Post by ScottyJones Thu Aug 02, 2012 2:35 pm
    So looks like it's gonna be about the same price for a rebuild or a reman. engine (around $1650). If I get the new motor we can just put it in and be done with it and not have to worry about swapping your old one in and out.
    BUT, let me see if I can scrounge up enough bread to pay for the damn thing…
    Post by donivan65 Thu Aug 02, 2012 4:08 pm
    looks like you and VanAgain are having a contest to see who can spend the most money on their green and white, 1965 Chevy SportVan Deluxes,,,
    Post by Twinpilot001 Thu Aug 02, 2012 4:14 pm
    COOL!! Racing another member!!! Nice !! affraid
    Post by ScottyJones Thu Aug 02, 2012 4:15 pm
    I would gladly take a cheaper option!
    Post by donivan65 Thu Aug 02, 2012 4:25 pm
    Thats why I am saying, you can rush out and pay full list price,,,,or do your homework and find the best deal,,,,,,Basically the engine and transmission are held in place by 3 bolts,,,,ain't no big deal pulling an engine out and putting one back in,,,,,it's just that when you get an engine out, you just gotta clean and paint everything before putting it back in,,,,that takes the most time,,,,but if you don't care to make your van pretty,,,,it goes really fast,,,,,,if you got the equipment and know what you are doing,,,,,
    Post by ScottyJones Thu Aug 02, 2012 4:40 pm
    Well then, maybe we'll just go ahead and put your old engine in until I either save up some money, or find somethin cheaper.
      Current date/time is Mon May 13, 2024 10:59 am
