    For those with 200 motors
    Number of posts : 437
    Registration date : 2010-12-14
    For those with 200 motors Empty For those with 200 motors
    Post by StuNami Thu Jun 21, 2012 2:49 pm
    Can someone measure the dipstick from the cap to the tip for me and the legnth of the tube? I have a new dipstick for a 200 but it's too long so I suspect either the tube in the block is too short or this really isn't a 200 dipstick that I just got.
    Thanks.
    Nami
    cl350rr
    cl350rr
    Number of posts : 287
    For those with 200 motors Empty Re: For those with 200 motors
    Post by cl350rr Thu Jun 21, 2012 5:26 pm
    cap to tip the stick measures 11-3/4"
    top to block the tube measures 3"
    and I really need to change my oil Rolling Eyes
    Post by StuNami Fri Jun 22, 2012 4:59 am
    cl350rr wrote:cap to tip the stick measures 11-3/4"
    Thanks! That helped alot.
    Cheers!
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Sat Jun 23, 2012 9:35 pm
    Stu,
    There are two different dipsticks. Some of the later 200's had a different oil pan with the sump in the rear, dipstick location is also in the rear. These won't clear the crosmember in a 65-67
    Fred
    Post by StuNami Sun Jun 24, 2012 3:34 am
    fmc56 wrote:Stu,
    Fred
    Hey Fred,
    Mine is a 1977 motor so mine is in the rear. I just put a new oil pan on and had to unbolt the crossmember but it fit fine. Do you have the length of the later dipsticks?
    Stu
    fmc56
    fmc56
    Post by fmc56 Sun Jun 24, 2012 9:15 am
    Stu,
    I don't have the length of the later ones but yours will be the same length as the 144, 170 that originally came in the van, same as Mustangs, Comets, Mavericks and Falcons. If you still need one I have a few early ones. I think the change was made around 1979/80 on the strut front suspension Fairmonts. Fred
      Current date/time is Wed May 08, 2024 5:06 pm
