where the seats in a100s customized to fit the u-shaped bar???? the track has to be moved in to fit the bar.....did Dodge just drill holes in a different location on regular seats??? or were they made that way from the factory???
seat mounts
Kip Page- Number of posts : 79
Registration date : 2010-04-27
seat mounts
Re: seat mounts
These are original A100 seats. To the best of my knowlege these were engineered for A100's and the only costonization (if any) would have been done for use in the factory racecars.
a100 seats
perfect these are the seats I need.....its hard to find these seats with the proper holes in the seats....I find seats but they dont have the right screw holes in them.....has anyone modified seats to make this work????
Re: seat mounts
The tracks are offset to clear the wheelhouse. I've not had to modify any other seats to fit, but I'm sure many here have and will be happy to help you out. I'm thinking an adaptor would not be too tough to fab up. Good luck, Joel
a100 seats and brackets
I have all the tracks and brackets but I dont have the seats.........
Re: seat mounts
Are you trying to find O.E.M. or are you going to put something different in there? The O.E.M. seats are found on e-bay often and sometimes at a decent price, it's the recovering in original style that costs big $$.
a100 seats
OEM.....
Re: seat mounts
I cut down the old OEM seats and attached them to Mustang II bases and used them in our A-100.
campin'fool wrote:These are original A100 seats. To the best of my knowlege these were engineered for A100's and the only costonization (if any) would have been done for use in the factory racecars.
do you have a pick of the passenger side wheel well mounts???
thanks for the pics for some reason mine are missing I guess I will have to have them fabed up
kp duster- Number of posts : 31
Registration date : 2012-07-24
Re: seat mounts
i have seat an slider if you still need them sell cheap needs covering
kp duster
kp duster
