    looking for a photo or diagram on how the wing window, spring, cam, washers, and nut go
    looking for a photo or diagram on how the wing window, spring, cam, washers, and nut go Empty looking for a photo or diagram on how the wing window, spring, cam, washers, and nut go
    Post by Guest Sun May 06, 2012 7:51 pm
    i replaced my wing window seals and now am not sure how all the parts go back together on the wing window splined pivot shaft
    thanks
    Number of posts : 2011
    looking for a photo or diagram on how the wing window, spring, cam, washers, and nut go Empty Re: looking for a photo or diagram on how the wing window, spring, cam, washers, and nut go
    Post by Barnabas Mon May 14, 2012 6:52 pm
    Here is a PDF picture that should give you what you need.
    http://econolineid.com/pics/econo_vent_window.pdf
    Post by Guest Mon May 14, 2012 7:53 pm
    thanks, now i see i have a lot of parts missing, but i did get a cam from a fellow member, and the rest i can find
    thanks all!!!
      Current date/time is Sun May 19, 2024 9:04 am
