    does 170 oil bath aircleaner come apart?
     does 170 oil bath aircleaner come apart? Empty does 170 oil bath aircleaner come apart?
    Post by Guest Fri Apr 20, 2012 10:22 pm
    i have a 1963 oil bath air cleaner and i need to take it apart to try to fix a dent in it.
    the top comes off the base, but i want to take out the part that holds the air filter mesh
    mine wont come part, before i bend something i wanted to see if there was a trick to getting them apart
    thanks
    Number of posts : 2011
     does 170 oil bath aircleaner come apart? Empty Re: does 170 oil bath aircleaner come apart?
    Post by Barnabas Sat Apr 21, 2012 6:32 pm
    They are not designed to come apart, but here is a thread detailing how to carefully cut one open in order to use a paper element.
    https://vintage-vans.forumotion.com/t24257-converting-oil-bath-air-cleaner
    And if you follow those instructions exactly, it will leak oil. You might be able to learn something from that procedure that will allow you to take yours apart, and still have it hold oil when you put it back together.
    Post by Guest Sat Apr 21, 2012 7:10 pm
    thanks
    that isnt what my 170 air cleaner looks like though
    mine is round and sits right over the top of the carb
    but one might infer from this that the 170 doesnt come apart either, wonder if i could do this to mine and fix the dent while it is gutted?
    can someone else chime in too please
    thanks
    Number of posts : 2067
    Post by sasktrini Mon Apr 23, 2012 1:04 am
    I've had mine apart, but don't remember how... somehow, I think the two halves twist apart... sorry.
    Post by Guest Mon Apr 23, 2012 8:05 am
    thanks ill keep fiddeling with it then
      Current date/time is Sun May 19, 2024 2:43 pm
