+7
thatcherworks
11 posters
    65 sportvan spring bushings
    65 sportvan spring bushings Empty 65 sportvan spring bushings
    Post by Guest Wed Apr 11, 2012 9:16 am
    Hello everyone, I have finally removed my front axle and leaf springs for king pin and bushing replacement. The springs on the front of the van are the same size on both the driver and passenger side. I have had no problem finding the HB930 bushing for the shackle end but I cant seem to find anything for the (front) cartridge end. Donivan, I am hoping you can tell me where you got this #2056 with#6 sleeve. Also I am going to have to replace the locating pin for the passenger side spring and one u bolt. I would be grateful for any help or suggestions. My local spring shops dont seem too interested.
    65 sportvan spring bushings Empty Re: 65 sportvan spring bushings
    Post by donivan65 Wed Apr 11, 2012 10:01 am
    I got them here,,,,I don't think they have a web store,,,,,they really are for 2nd Gens, and since 2nd gens have 3" wide springs and 1st Gens have 2" wide, you need to trim the neoprene and sleeve off a little,,,,but it fits great! I sent Devimau over there to get some and they sold him some cartridges,,,,,,and they fit good,,,,so,,,,,there is a chance that those 2nd Gen cartridges can be cut down to fit a 1st Gen,,,,,I am going to go buy one and see if I can make it fit a 1st Gen spring. I bought other cartridges, but they were a sloppy fit,,,,they need to be a press fit. OR,,,,,,call them,,,,pay for them and I will go down there and pick them up and mail them to you if you can't find another place that sells them,,,,,,those just seem like normal bushings that an off road or 4WD shop would have ,,,,,,
    http://www.nationalsprings.com/
    Post by donivan65 Wed Apr 11, 2012 11:05 am
    65 sportvan spring bushings Spring22
    65 sportvan spring bushings Spring23
    Post by Guest Wed Apr 11, 2012 6:37 pm
    Thanks Donivan,
    I will get my old bushings pressed out so I can get a better o.d. measurement and give them a call. There is a 4wd shop here I can try, I did not think of that. There is surely somwhere close by I can find these parts. There have been so many good posts on this site that many times I don't have to ask a question because it has already been answered. I sure appreciate the help.
    Post by donivan65 Wed Apr 11, 2012 8:13 pm
    65 sportvan spring bushings Vanaga24
    Post by donivan65 Wed Apr 11, 2012 8:53 pm
    The neoprene are 1.134 diameter, and thats what I think the original metal cartridge bushings are,,,those new 2 1/2" wide metal ones are 1 1/8" (1.125),,,,,but I need to buy one of those 3" wide ones,,,,they fit REAL GOOD in a 2nd Gen spring,,,,,so if they fit in a 1st Gen spring, then we need to whack off an inch,,,,,,
    65 sportvan spring bushings Repai245
    Number of posts : 1279
    65 sportvan spring bushings Empty leaf spring replacement
    Post by Space Truckin Wed Apr 18, 2012 9:18 pm
    donivan65 wrote:65 sportvan spring bushings Vanaga24
    Donivan , in the picture there are 2 red bushing cartridges ? next to a stack of 8 black bushings , will the red bushing cartridges fit new 2 1/2" springs for a 2nd gen? Just purchased new springs from Atlas spring and am very confused on fitment {orig spring seem to be 4" at body mount/perch , new are 2 1/2" ?)
    Last edited by Space Truckin on Wed Apr 18, 2012 9:33 pm; edited 1 time in total (Reason for editing : more info)
    Post by donivan65 Wed Apr 18, 2012 10:44 pm
    I was looking for you when I left Pasadena,,,The Black HB 930 are for the Shackles,,,they are for 2nd Gens and can be cut down for 1st Gens,,,,2nd gens are 3" at the bushings, (2 1/2" at the U Bolts),,,1st Gens are straight 2",,,,,,so no problems for 4 shackle bushings on each spring...now that metal cartridge is a different story,,,,I have never found a 1st Gen one so I put those red ones with a sleeve in place of it,,,,,and just last week, the spring shop sold Devimau a metal cartridge called RB 99 and it fit PERFECT,,,,so I will be going to National Spring and buying one and seeing if I can get it to fit a 1st Gen,,,,but those black ones and that cartridge are PERFECT FIT for 2nd Gens,,,,,
    65 sportvan spring bushings Chevy176
    Post by donivan65 Wed Apr 18, 2012 10:50 pm
    I hope the spring shop knew that you needed 3" springs and they need to be cut down in the middle so the 2 1/2" U bolts will slide over them,,,,,
    65 sportvan spring bushings Empty leaf springs
    Post by Space Truckin Thu Apr 19, 2012 4:58 am
    No my springs are 2 1/2" inch all the way down , I got new u bolts at the same time. I am concerned about the slop at the mount points . What is o.d dimension of the red cartridge ( total cartridge length )
    I believe my mount dim at body and shackles is 3 5/8 inches
    Post by donivan65 Thu Apr 19, 2012 8:50 am
    So those are not the right springs and you want to make them work,,,,,3 5/8 is what the front spring saddle is,,,,,,,and that is how wide the bushings are,,,,,,they stick out about 1/4" on each side from the 3" wide springs,,,,but you need to add washers to the red bushings to fill that 1/2 space that you now have with those skinny springs,,,,,,,HOWEVER,,,,the RB-99 at National Spring is 3 5/8 so they would hang out 1/2" and hold your springs from sliding side to side,,,,,,IF,,,,you get a tight fit,,,,,and that is a BIG PROBLEM,,,,,you need a crush fit to press the metal ones in and a REAL ACCURATE hole and bushing measurement if you are pressing in metal cartridges,,,,,,and I don't think all holes in the springs are the same,,,,you can't use a loose metal cartridge in there,the whole axle will slide left and right,,,,I think the red bushings with flat washers will be easier to do,,,,,,
    65 sportvan spring bushings Spring25
    Post by Space Truckin Thu Apr 19, 2012 10:56 am
    Spoke to Ben at National Springs this a.m , hopefully I am on right track
    Post by donivan65 Thu Apr 19, 2012 1:06 pm
    So what are you going to do,,,,,get the red # 2056 bushings and a #6 sleeve and add some flat washers to take up the slack or the RB-99 metal cartridge,,,,,The shackle ends are HB 930,,,,,,I will probably go see Ben Tomorrow and get one of those cartridges he calls RB-99,,,,,,that might not be their real number, but they sure are the right ones for a 3" wide 2nd Gen spring,,,,,,
    Post by Space Truckin Thu Apr 19, 2012 6:06 pm
    Don't know what factory size is , but have talked to Deavers , St Louis , Detroit Eaton and Atlas and all of them build the same 4 leaf 2 1/2 wide spring for a a 67 g10 , keeping my fingers crossed .Ben is very knowledgeale when it comes to his springs/bushing ?
    Post by donivan65 Thu Apr 19, 2012 6:39 pm
    Why don't you crawl under your other 2nd gens and tell me how wide their springs are,,,,,,,
    Post by Space Truckin Thu Apr 19, 2012 7:50 pm
    Will do , front what I understand they start at 3" and taper to 2 1/2" +/-
    Post by Space Truckin Fri Apr 20, 2012 8:44 am
    Donivan , just ordered bushings for springs at shackles and frame , National is going to provide a modified Energy 2043 for shackles and a modified Energy 2007 for frame .(Note part #'s are for 67 G10 350/350th)
    Post by donivan65 Fri Apr 20, 2012 10:05 am
    The upper shackle bushing would have to be stock, while the lower bushing and cartridge would have to be a shimmed type to mount those skinny springs,,,,,and if you say they are 67 350/TH350 part numbers, there aint no such van like that,,,,,I would of thought that if you got the correct 3" wide springs and used a grinder to adjust them for the u bolts to fit, you would of found the correct bushings,,,,,,,but lets see what you get,,,,,,,
    Post by Space Truckin Fri Apr 20, 2012 12:39 pm
    It was an original 283/3spd , he swapped in 97 to a 350/350
    Post by donivan65 Fri Apr 20, 2012 2:20 pm
    Thats your problem,,,,you are NOT ordering parts for a Van,,,,,you are trying to put some Jeep springs or something on a van,,,,,,I would be bringing the old springs and new springs to a spring shop and ask them for adapter bushings to make the new ones fit,,,,,,
    Post by donivan65 Fri Apr 20, 2012 6:29 pm
    I just come from National Spring,,,,they are out of RB-99 but they are sending you sleeves and FAT bushings to make those springs fit your van,,,,,,
    Post by Space Truckin Fri Apr 20, 2012 9:42 pm
    I told Ben you would be in today , he said bushings should ship today . When I receive them will install and let you know how they fit . study
    Post by donivan65 Fri Apr 20, 2012 9:56 pm
    Did he tell you what sleeve numbers you were getting,,,,probably #6 is going in the shackle end,,,and what about the upper shackle bushings,,,you can't use fat ones there,,,,,they take HB 930 and as usual, National Spring is out of them and might not ever get them anymore,,,,,and what is your front bolt size 1/2" or 9/16"?
    Post by Space Truckin Fri Apr 20, 2012 10:04 pm
    No he didn't give me sleeve #s , am hoping when I get invoice it will have pertinent part #'s . He is shipping upper/lower shackle end bushings front and rear . Will go to locker in am and get closer look at everything Wink
    Post by donivan65 Fri Apr 20, 2012 10:35 pm
    That's not sounding good,,,,in my book, you don't need to change the upper bushings,,,,they are HB 930's and Ben has been out of them for years,,,,,,so what is he sending you,,,,fatter ones to make the shackles even fatter?
    You might call and ask him what, or if, he is sending for the uppers,,,,,,,,and then the question is DO YOU NEED THE UPPER HB 930 BUSHINGS,,,,,and I know where to get them,,,,,,
      Current date/time is Sun Apr 28, 2024 7:31 am
