    does the gas tank fill tube have a gasket to body?
    does the gas tank fill tube have a gasket to body? Empty does the gas tank fill tube have a gasket to body?
    Post by Guest Sun Apr 01, 2012 10:08 pm
    took the gas fill tube out of the body today to repaint it and noticed there wasnt a gasket there between the body and filler flange.
    wondered if there ever was one there?
    i noticed the gas cap sits a little far away from the body and a gasket would bring it closer
    thanks
    Number of posts : 2198
    does the gas tank fill tube have a gasket to body? Empty Re: does the gas tank fill tube have a gasket to body?
    Post by EconoUSAparts Mon Apr 02, 2012 7:01 pm
    No gasket from the factory. You can always try adding one
    cl350rr
    cl350rr
    Number of posts : 287
    Post by cl350rr Mon Apr 02, 2012 7:34 pm
    you may not want to add a gasket, you want your filler neck well grounded to the body of the van when you are fueling to disapate static electricity that builds up
    Post by donivan65 Mon Apr 02, 2012 7:39 pm
    If you have screws on it that hold it to the body,,,,that would ground it and make a gasket a good idea,,,,,,
    cl350rr
    cl350rr
    Post by cl350rr Mon Apr 02, 2012 7:45 pm
    just sayin that might be the reason there is no gasket from the factory
    Post by donivan65 Mon Apr 02, 2012 10:56 pm
    Probably the best thing a gasket would do is move the gas cap in closer to make it look better,,,,,,
    Post by Guest Mon May 28, 2012 7:33 am
    all good points thanks
    got some rubber and cut a gasket, and to me it was worth it as now the gas cap looks to fit better to the body
    also made sure it was still grounded
    ps i made a gas cap cover out of an old econoline horn button, looks sharp to me
      Current date/time is Sat Apr 27, 2024 10:42 am
