    1st gen fuel tank lock ring and gasket
    1st gen fuel tank lock ring and gasket Empty 1st gen fuel tank lock ring and gasket
    Post by Guest Wed Oct 21, 2015 8:11 pm
    Looking at past threads, is the fuel tank lock ring and gasket(part # LO02) that Donivan had posted fit the first gen fuel tank also? He stated that it would fit the '67 tanks . Just wanted to know if it will fit the first gen tank. Thanks
    1st gen fuel tank lock ring and gasket Empty Re: 1st gen fuel tank lock ring and gasket
    Post by donivan65 Wed Oct 21, 2015 8:45 pm
    1964-70 tank sending units are the same except for the resistance units hanging on them,,,,,
    1st gen fuel tank lock ring and gasket Dscn7027
    Number of posts : 1412
    Post by Vantasia Thu Oct 22, 2015 6:47 am
    The rings and gaskets are the same as any GM car from that time, many on eBay listed.  There is also a special tool that makes removing and installing the ring easy without bending the tabs with a hammer and screwdriver:
    http://www.ebay.com/itm/GM-Gas-Fuel-Sending-Unit-Lock-Ring-Tool-Wrench-68-69-70-71-72-Corvette-NEW-/360986170272?fits=Make%3AChevrolet&hash=item540c73d3a0:m:mZYFLklhXSjMz-m3RfPKsYw&vxp=mtr
    Very handy if you do a lot of tank work.
    1st gen fuel tank lock ring and gasket Empty 1st gen lock ring
    Post by Guest Thu Oct 22, 2015 2:26 pm
    Thank you both, Donivan &  Vantasia, for the info and pictures.
      Current date/time is Wed May 08, 2024 5:47 am
