g'day again I need more help. I am desperate for a radiator for my van. it has 273. could anyone please let me know where to get one or how mucc. the tanks are good but core is split. thanks wobbss
radiators help
Stoopid john- Number of posts : 265
Re: radiators help
I bought an aluminum one for a 32 ford and it well, with a little work.
https://vintage-vans.forumotion.com/t22811-my-radiator-fix
- Number of posts : 8732
Re: radiators help
http://www.fsrradiator.com/ the rad in the photo is what i installed call them tell them what you have . the measurements work but you'll have to sut off 1 flange from each side and drill some holes to fit the housing. also there is also some cutting on the top of the rad housing. what i did was drill out the spot welds , remove that plate and ifter installing the rad i made a new plate,,,shouls be under $300 for a 3 core rad....
equium- Number of posts : 107
Registration date : 2011-04-25
Re: radiators help
I don't think your link got us all the way. Can you verify which Radiator you got from them. I'll be in the market for one pretty soon.dix wrote:http://www.fsrradiator.com/ the rad in the photo is what i installed call them tell them what you have . the measurements work but you'll have to sut off 1 flange from each side and drill some holes to fit the housing. also there is also some cutting on the top of the rad housing. what i did was drill out the spot welds , remove that plate and ifter installing the rad i made a new plate,,,shouls be under $300 for a 3 core rad....
thanks
kp duster- Number of posts : 31
Registration date : 2012-07-24
Re: radiators help
i have a good
one
one
