Hey there,
My OEM 273cid LA motor runs well enough but it's on my list of things to do to build a mild "street performance" replacement. Due to the rarity/cost of 273 performance parts and the smaller displacement of said engine I'm considering either building a 318 or 360 instead and saving/storing the 273 as "original parts".
Since the physical size of the 318/360 is the same I'd rather have the 360 for the added CID. I can think of a couple concerns right off the bat which I'll list below, anyone else know of anything I need to pay attention to?
concerns:
1) My 273 has an A745 3-speed manual behind it, I think the slant6 and 273 used a 10" clutch assembly, the 318 used a 10.5" (which I could use with the 360 I guess). The diameters I listed may not be spot on since I didn't refer to my docs but I do know there are two different clutch sizes for the different engines.
My basic build will be:
~4bbl 600'sh CFM carb and intake
~shorty/hugger headers (wrapped or coated)
~pretty heavy cam, more so for the sound and "Car show appeal" than anything else
~high flow water pump (and probably a new 4 core radiator)
~possible upgrade to electronic ignition but that's not a must have.
I'm not going to race it, just want to have a little better performance, sound and looks.
concerns:
