    where to look
    where to look - Page 2 Empty engine id
    Post by Guest Sat Dec 13, 2008 8:52 am
    look for the the numbers near the bottom of the engine by the exhaust manifold/exhaust pipe connection. Then go to classicmustang.com/decoding if it is a ford it will tell you the model/size of the engine
    where to look - Page 2 Empty Re: where to look
    Post by Guest Mon Jan 19, 2009 8:49 am
    hey, i finally found those numbers, and unfortunately this decoding link is not working.
    the numbers are C5DE
    6015-G
    (and far on the left there is a single number Cool dont know if this is important
    thanks
    Post by Guest Mon Jan 19, 2009 9:02 am
    hey, now i know it came out of a 1965 falcon!
    Number of posts : 2198
    Post by EconoUSAparts Mon Jan 19, 2009 8:08 pm
    If its a stock type early econo tranny then it wont have a crossmember. It will hang from a loop attached to the floor area. If it is a stick (original for a 62) then see if it has an access plate on top(top loader,synchronized),if no plate then its a non synchro first gear,original probably but not desireable. Auto trannys werent available til 64.
    Post by Guest Wed Jan 21, 2009 12:17 pm
    well, i finally got the seal in that tranny!
    now i just need to fix the other problems
      Current date/time is Sat May 18, 2024 7:11 pm
