    where to look
    where to look Empty where to look
    Post by Guest Thu Dec 04, 2008 4:58 pm
    how do i know what tranny i got?
    its a 62 falcon clubwagon
    the engine is not the original (and i still dont know what i got)
    its 3 sp manual
    where to look Empty Re: where to look
    Post by Guest Thu Dec 04, 2008 6:30 pm
    im looking to get the rear seal price on the autozone page
    and its asking if its the Warner T86 transmission,
    or this T89 transmission,
    or Warner model T87 transmission.
    i walked to the store and they dont have any of the seals so that i can compare them with the one the van has
    thanks..
    Number of posts : 7900
    Post by DanTheVanMan Thu Dec 04, 2008 8:01 pm
    Though the early falcons came with the "T3" or Type "C" Tranny...
    and I believe your motor would be one of these.
    144 cid I6
    170 cid I6
    240 cid I6
    where to look Qr_cod10
    Post by Guest Fri Dec 05, 2008 3:19 pm
    how would i know the difference between the three ?
    Post by DanTheVanMan Fri Dec 05, 2008 4:54 pm
    What color is you Engine block and Rocker cover?
    And what's your VIN#
    Post by Guest Mon Dec 08, 2008 3:33 pm
    the engine block is blue,
    the cover has orange under blue paint (repainted at some point)
    and the vin is E13TH231788
    hope this helps.
    thanks
    Number of posts : 987
    Post by RipVanArkie Mon Dec 08, 2008 3:50 pm
    Can you post a pic of the engine? Are you looking for the rear seal on the trans? What is the number cast on your engine block, head, intake manifold? All of these will help. If the trans is original this should be easy.
    Most likely: BCA/NATIONAL Part # 470059
    Later,
    Rip
    Post by Guest Mon Dec 08, 2008 4:06 pm
    the intake number is C3De-6090-Dx5
    (where can i find the engine and head numbers) Question Crying or Very sad
    i was thinking of just getting the rear one, but its better if i just put them all.
    Post by DanTheVanMan Mon Dec 08, 2008 4:15 pm
    DanTheVanMan wrote:What color is you Engine block and Rocker cover?
    beanses, If you can answer these questions. I can tell you all about your veh.
    Post by RipVanArkie Mon Dec 08, 2008 4:47 pm
    Block number will be found below the manifolds, near the oil pan. If the trans is hanging from the original mount it is likely original and the above part number should be correct, it is the only one listed for the Econoline in 62. Your engine is a 63-65 200CID based on the intake number. Hopefully they only replaced the engine, in 65 there are 5 choices for the output shaft seal!
    Good Luck,
    Rip
    Post by RipVanArkie Mon Dec 08, 2008 4:49 pm
    Unless something has been changed... he know's the engine is not original.
    Post by DanTheVanMan Mon Dec 08, 2008 5:00 pm
    It's ok, They color coded the engines. We can still let him know what size puppy he's got in that dog house.....
    Unless it was a complete conversion... Then who knows. Question
    Post by Guest Tue Dec 09, 2008 10:51 am
    well, the engine block is blue, the cover has orange with blue on top and the vin # is E13TH231788
    the trans is hanging from that support,
    are there any numbers on the trans case to look for?
    i have to clean that engine really good, but the wether...
    Post by DanTheVanMan Tue Dec 09, 2008 12:34 pm
    Well, looks like you have a "260 cid"Challenger V8"
    And this is what it had origunally
    TH - V8 292 CID 1x2BBL 175 hp Export 1-2BBL
    Post by Guest Tue Dec 09, 2008 2:49 pm
    well that just blew me off.
    its not a v8.its a I6 and if the TH means that, then i have to check on the previous owner and see what happened... Surprised
    Post by RipVanArkie Tue Dec 09, 2008 5:52 pm
    Dan, are you alright man, this is a van we are talking about... they didn't come with V8 engines.
    Beanses, according to your VIN, you have a 62 Falcon Club Wagon. The 'T' means it came with a 170 CID 6cyl engine and the 'H' means it was built by the Ford factory in Lorain, OH. If you can give me the other two lines on your VIN plate, I can tell you more.
    Later,
    Rip
    boroop
    boroop
    Number of posts : 92
    Post by boroop Wed Dec 10, 2008 11:25 am
    beanses wrote:62 falcon clubwagon
    Research your VIN here.
    Post by RipVanArkie Wed Dec 10, 2008 4:38 pm
    Thanks boroop, I didn't have that link, I was using a factory manual.
    Later,
    Rip
    fmc56
    fmc56
    Number of posts : 553
    Post by fmc56 Wed Dec 10, 2008 5:26 pm
    Since you have what seems to be the original transmission here's a link to Advance Auto's website with the part you need. http://shop.advanceautoparts.com/ProductList.aspx?PartType=1203&PTSet=A I bought one from them a few years ago at a local store. It fit perfect. The original transmission in 61/62 is a non-synchro type with a solid driveshaft, yoke slides into the transmission. This is what you should have. If not they could have also switched the transmission also. In 63/64 they changed to a driveshaft with a slip yoke in it and a full synchro transmission which has the u-joint bolted to it. Both use the same single bolt donut style hanger mount. In 65/67 the mount style was changed.
    Fred
    Post by DanTheVanMan Wed Dec 10, 2008 6:21 pm
    Ahhh yes. Ask and you shall receive. Beanses, This is why we are all here. If you can ask it. Someone has dealt with it or knows someone who has.
    cheers cheers cheers cheers cheers cheers
    Post by Guest Thu Dec 11, 2008 8:03 am
    thank y'all
    now i just have to deal with the wether.
    boroop
    boroop
    Post by boroop Thu Dec 11, 2008 12:39 pm
    beanses wrote:thank y'all
    In El Paso?
    You'll get no sympathy here... it's 30-some degrees and snowing this week. Evil or Very Mad
    Number of posts : 1605
    Post by itruns Thu Dec 11, 2008 3:58 pm
    In El Paso?
    +1 This crap isn't supposed to being sticking till after Christmas. Mad
    Good luck beanes. I hope you got things straighten out.
    Post by DanTheVanMan Thu Dec 11, 2008 6:42 pm
    O'Yeah,
    It was so cold here I had to put on a long sleeve shirt to go for a ride on the bike.
    It was a freezing 65 degrees. Like a warm Michigan summer day...lol cheers
    I'm laughing because we're moving back to Upper Michingan this spring...
    I'm going to freeze my a$$ off next winter!!! pale
    boroop
    boroop
    Post by boroop Fri Dec 12, 2008 5:10 am
    Where ya moving back to? My folks are in Pellston until the 2nd or 3rd snow fall... then they head for Florida. rendeer
      Current date/time is Fri May 17, 2024 1:28 am
