    65 chevy brake light switch at master cylinder install info needed
    ditdater
    ditdater
    Number of posts : 590
    65 chevy brake light switch at master cylinder install info needed Empty 65 chevy brake light switch at master cylinder install info needed
    Post by ditdater Sat Nov 12, 2011 7:23 pm
    hopefully this will get brake lite working ,all other lites work . can anybody assist w/ tips on install. thanks dt
    65 chevy brake light switch at master cylinder install info needed Empty Re: 65 chevy brake light switch at master cylinder install info needed
    Post by donivan65 Sat Nov 12, 2011 8:27 pm
    To replace the brake light switch, you need to unplug the 2 wires, and remove the 2 bolts that hold it to the floor,,,,,,,the arm on it goes above the brake pedal arm,,,,,
    65 chevy brake light switch at master cylinder install info needed Repai128
    ditdater
    ditdater
    65 chevy brake light switch at master cylinder install info needed Empty take off belly pan??
    Post by ditdater Sun Nov 13, 2011 12:48 pm
    i/m guessing the best way to get to it is removing belly pan ?
    Post by donivan65 Sun Nov 13, 2011 12:51 pm
    YEP,,,,,,and the terminals on it could be corroded or loose, making it not work,,,,
    ditdater
    ditdater
    65 chevy brake light switch at master cylinder install info needed Empty thanks for the reply.....
    Post by ditdater Sun Nov 13, 2011 1:25 pm
    i am diggin' this site . Very Happy
    Post by donivan65 Sun Nov 13, 2011 4:24 pm
    ,,,,and all you have to do is bring a shovel,,,,,
    Post by donivan65 Sun Nov 13, 2011 5:49 pm
    65 chevy brake light switch at master cylinder install info needed Repai133
      Current date/time is Tue May 07, 2024 9:54 am
