    How can I determine head cu's?
    How can I determine head cu's? Empty How can I determine head cu's?
    Post by Guest Sat Nov 12, 2011 3:56 pm
    Hi everyone! This is my first post. Very confusing site so far. I am having a terrible time finding a replacement exhaust/intake manifold. I think part of the problem is that I am not sure if the head is a 230 or a 250. I got this van in 1973 and a mechanic changed the head. I think he put on a 250. I do know that the 3/4 plugs are too big. I have to use the 5/8. Does this mean it is not a 230?
    Secondly, since I cannot locate a manifold, can I put headers on? I looked at some online today and I can't understand how they work. What happens to the intake part of the manifold? The carburetor "box", on the intake part of the manifold bolts up to the exhaust part of the manifold. Of course there is no place to do this with a header - so how does that work? Is this even possible?
    Number of posts : 1388
    How can I determine head cu's? Empty Re: How can I determine head cu's?
    Post by wideload Sat Nov 12, 2011 5:01 pm
    Scott the heads on the chevy 6's are interchangeable between all the different engine sizes. The cubic inch sizing is determined by the bore and stroke of the motor. If you go with headers you'll probably need to go with an after market intake also, there are several brands available, stove bolt and clifford are two of the more popular ones. Check the local junk yards and you should be able to find a manifold. A 194,230,250, or 292 cubic inch should work.
    Post by donivan65 Sat Nov 12, 2011 9:12 pm
    Those 6 cylinder Chevy heads come in 2 flavors,,,,the older ones have separate intake and exhaust, (like this picture)manifolds,,,,,the newer ones, after 1980, only have an exhaust manifold,,,,,the intake is built into the head,,,Do you really need both manifolds? Headers just hook up to the 6 exhaust ports,,,,they sit under the intake manifold.......Ask whatever is confusing you about this site and we will explain it so you will have no more problems with it.....
    How can I determine head cu's? Repai129
    Number of posts : 890
    Post by jrinaman Sat Nov 12, 2011 10:07 pm
    if you really want headers, you need shorties like cliffords for around $400.00. long tube headers are listed to fit our vans but are way to lowHow can I determine head cu's? Van_en12 a better choice would be langdons for less than $300.00How can I determine head cu's? Intake14 you need to install a heat plate and run water to heat the intake. if you just want it fixed, do as others suggested and call a few junkyards or check craigslist, theyre out there.
    How can I determine head cu's? Empty reply
    Post by Guest Sun Nov 13, 2011 7:14 am
    [quote="donivan65"][size=18]Those 6 cylinder Chevy heads come in 2 flavors,,,,the older ones have separate intake and exhaust, (like this picture)manifolds,,,,,the newer ones, after 1980, only have an exhaust manifold,,,,,the intake is built into the head,,,Do you really need both manifolds? Headers just hook up to the 6 exhaust ports,,,,they sit under the intake manifold.......Ask whatever is confusing you about this site and we will explain it so you will have no more problems with it.....
    Thank you for your reply. I want to reply back to this post only. Not sure of the direct path to do that. I have clicked on the "quote" button. I tried first to click on your email address. The field in which to type my message is black - I could not see the text I was typing - hence the "quote" button route....Regarding my exhaust/intake issue. I only need to replace the exhaust - BUT the intake bolts to it. How is that issue resolved if I install a exhaust header? In your picture (I am almost certain it is the same part I need) the two threaded posts that are shown is where the intake bolts to the exhaust - that is where the carb sits. Again, my intake is fine and I have a new carburetor. As I learn more it seems I have two options: keep looking for a exhaust manifold or install a exhaust manifold, and a intake manifold and a new carburetor. Am I getting this correct? Again, thank you.
    Post by Guest Sun Nov 13, 2011 7:16 am
    Post by donivan65 Sun Nov 13, 2011 9:53 am
    [quote="cscott"]
    donivan65 wrote:Those 6 cylinder Chevy heads come in 2 flavors,,,,the older ones have separate intake and exhaust, (like this picture)manifolds,,,,,the newer ones, after 1980, only have an exhaust manifold,,,,,the intake is built into the head,,,Do you really need both manifolds? Headers just hook up to the 6 exhaust ports,,,,they sit under the intake manifold.......Ask whatever is confusing you about this site and we will explain it so you will have no more problems with it.....
    Lets talk about this QUOTE THING,,,,,I just clicked on QUOTE on your message, I go down and find the end of the very last thing you wrote and I started typing this message right after it,,,,,thats it,,,,Press Preview to see how it changes it and Send it if you like what you see,,,,,,This QUOTE thing is a REALLY GOOD way to go back and reply to a certain post that you want to talk about.......
    Post by donivan65 Sun Nov 13, 2011 11:00 am
    Here are some pictures of the REAL 6 cylinder Chevy manifolds,,,,,there are probably a million in the wrecking yards....Headers are a complicated way to go,,,And as for Emailing someone, we all got private mailboxes here,,,just go to the arrow in the upper right hand corner next to their name of anyones post and choose PM,,,,then you can send them a Private Message and not be TV here,,,,,(I think I will send you one right now,,,)
    How can I determine head cu's? Repai130
    How can I determine head cu's? Repai131
    Post by Guest Sun Nov 13, 2011 12:41 pm
    I have taken a second look at the pictures you sent earlier. Whatever year my van's head is - your manifold picture looks like my manifold. The placement of the threaded bolts is the same and if you turn the manifold over - the two middle ports are divided - into two compartments. Correct?
    Post by donivan65 Sun Nov 13, 2011 12:59 pm
    There is a better picture in your Parts Wanted post,,,,,it don't really matter if the exhaust flange has 2 or 3 bolts on it, as long as the intake, ports and bolt holes line up
    Post by Guest Sun Nov 13, 2011 2:01 pm
    The 3 bolt configuration manifold has the pipe oriented in a whole different direction and I would have to have my pipe bent to accommodate.
    Post by donivan65 Sun Nov 13, 2011 10:26 pm
    Hey other Scott from Texas with a Chevy van, did you have to get the exhaust pipe modified when you used a 3 bolt exhaust manifold flange?
    Post by Guest Mon Nov 14, 2011 6:18 am
    I sent that manifold back, thinking it was too much hassle. Today a manifold that will fit - according to pictures AND measurements, is being shipped. It's off a 250, so I guess my head is a 250. Still not sure of the year....
      Current date/time is Tue May 07, 2024 7:24 am
