    Rear truck suspension
    Rear truck suspension Empty Rear truck suspension
    Post by Guest Thu Oct 13, 2011 1:09 pm
    I was looking at my rear suspension and it has coil and leaf springs. Is this the way they came stock? I may post a pic later if it's not stock so you guys can see Smile
    Number of posts : 575
    Rear truck suspension Empty Re: Rear truck suspension
    Post by austinmodhouse Thu Oct 13, 2011 1:19 pm
    some shocks have a small spring on them, or do you have a full on coil/over?
    Post by Guest Thu Oct 13, 2011 2:02 pm
    austinmodhouse wrote:some shocks have a small spring on them, or do you have a full on coil/over?
    I agree he is probably talking about springs on load leveler shocks.
    Post by Guest Thu Oct 13, 2011 5:02 pm
    They aren't on the shocks. They go from the axle tubes to the frame
    Post by Twinpilot001 Thu Oct 13, 2011 5:42 pm
    In the old days before = air bad suspension= there were shocks available with a coil spring on the outsides of them = monroe called =Load levelers =[ these were the best even before "air Shocks " came about - I still use them on most of mt vehicles too. Better than air shocks unless u are varing the heavy loads in back. Happy Vannini]
    Post by Guest Thu Oct 13, 2011 6:34 pm
    They aren't on, or any where near the shocks... I didn't get any pics today but I will tomorrow and post them up here
    Post by Guest Thu Oct 13, 2011 6:40 pm
    If you have coil and leaf then it is not stock. Our earlies came with leaf springs
    Post by Guest Fri Oct 14, 2011 11:03 am
    Post by Guest Fri Oct 14, 2011 11:16 am
    someone added those springs and those sets are up to high and mickey moused badly.
    Post by Twinpilot001 Fri Oct 14, 2011 11:20 am
    That install was a dealer and aftermarket add on - I just removed a set from my 64 Ranchero-same ones .
    Post by Guest Fri Oct 14, 2011 11:31 am
    Is that the stock rear end? I can't find any info on anything with an 8 bolt cover
    Post by Guest Fri Oct 14, 2011 11:37 am
    I know the seats are to high cuz I can't bottom out any of the pedals lol. They will be replaced eventually before I start driving it. Right now it's just sitting in the yard with a few other classics. A 1965 Mercury, 1959 Pontiac Catalina, and a 1956 Chrysler New Yorker with a hemi. They aren't mine, just the truck, but the hemi sounds awesome Smile. I need to do some work on them hopefully before car show season starts again.
    Post by Guest Fri Oct 14, 2011 11:51 am
    I was in the process of getting a 1966 Plymouth Baracuda my uncle gave me back in 2010 but ended up moving across the country to help him and my aunt. It needed a lot of work but it was the first car my uncle ever owned and it would have been nice to fix it up. All his life he wanted a car with a hemi in it and was happy when he found the New Yorker for $600 and drove it home. He had a lot of plans for what he was going to do with it but cancer ended up taking him 4 days before Christmas. Cancer really sucks Sad
      Current date/time is Sun May 19, 2024 11:44 am
