    Gas Gauge on E
    Number of posts : 361
    Gas Gauge on E Empty Gas Gauge on E
    Post by ScottyJones Fri Oct 07, 2011 10:11 am
    This may vary from van to van, but how far should the needle go beyond the last mark before I should worry about running out of gas? Razz
    I know when I fill up, it goes past the full mark by quite a bit...
    Number of posts : 648
    Gas Gauge on E Empty Re: Gas Gauge on E
    Post by Rayallen Fri Oct 07, 2011 10:16 am
    If its anything like my van fill up before you get to a 1/4 tank. I ran out of gas thinking I had a 1/4 tank left, haha. Luckily I was close to my house.
    Post by Guest Fri Oct 07, 2011 1:46 pm
    The sending unit may be "old" and not providing an accurate representation of fuel to the gas guage - you could replace the sending unit or just run it out of gas (with a gas can full of fuel in the back) and then you will know. LOL
    Post by donivan65 Fri Oct 07, 2011 2:59 pm
    The tank holds 16 gallons, so when it gets down to 1/2, see if it takes 8 gallons to fill it up,,,,,see if 1/4 takes 12 gallons, That will give you an idea on of how low you can let the gauge go before you start walking,,,,,,you kind of want to know where the gauge reads when you are down to your last 3 gallons and it's time to fill up the tank,,,,,,you don't want to run out going up Texas Street,,,,,,
    Number of posts : 1293
    Post by Lazarusvan Sun Oct 09, 2011 5:49 am
    Donivan, thanks for a perfect solution and answer to the same question I had.
    Yet another question related to this subject:
    What causes the gas gauge indicator to have float? Is it the sending unit? Trying to learn what I need to do to address these things.
    Post by Twinpilot001 Sun Oct 09, 2011 7:00 am
    For what its [ affraid worth?? my experience always has been - when a ford shows empty- you will be walking very soon - when a chev shows empty you still have about 20-30 miles to drive for fuel. Just an observation of 50 years .Im not talking about teh new ones with a fuel low warning lights =]
      Current date/time is Wed May 01, 2024 5:49 pm
