PolarBear2
bluefever
    new to the forums
    bluefever
    Number of posts : 24
    Registration date : 2008-11-26
    new to the forums Empty new to the forums
    Post by bluefever Wed Nov 26, 2008 8:38 pm
    hi, i'm new to the forums,i've mainly been a toyota van enthusiast,but when i noticed a dodge van,i decided i have to have one,i don't have one yet,but i'm going to be checking out a 67 dodge sportsman,it has the 225 slant six and an auto transmission,i'm considering possibly restoring it since the guy doesn't want hardly anything for it,he says it ran fine when he put it up 20 years ago,i know really long time!how hard would it be to get it running again?
    new to the forums Empty Re: new to the forums
    Post by G-Man Wed Nov 26, 2008 8:50 pm
    bluefever wear are you from??? Something sitting that long every seal & gasket will be shot in that motor. I would get it only if it has a good body and just put something fresh in there. I'm not saying you couldn't get the old engine running, but you will be chasing leaks for a while
    bluefever
    Post by bluefever Wed Nov 26, 2008 8:52 pm
    new hampshire,body seems good from the pictures,won't truly be able to tell though till i go see it next week
    Post by G-Man Wed Nov 26, 2008 9:07 pm
    Is this the van you are talking about???
    https://vintage-vans.forumotion.com/a-vans-for-sale-f20/67-sportsman-ridden-hard-put-up-wet-t2440.htm
    If so from what I see it would take alot to bring this one back. Some guy's are up for the challenge, but if you can't do body work leave this one to someone else.
    PolarBear2
    PolarBear2
    Number of posts : 183
    Post by PolarBear2 Thu Nov 27, 2008 3:01 am
    Welcome to the Forum
    Good luck with your search
    bluefever
    Post by bluefever Thu Nov 27, 2008 4:21 pm
    i'm up for the challenge can do bodywork,weld,and torch.
    Number of posts : 1605
    Post by itruns Thu Nov 27, 2008 4:39 pm
    G-Man wrote:bluefever wear are you from??? Something sitting that long every seal & gasket will be shot in that motor. I would get it only if it has a good body and just put something fresh in there. I'm not saying you couldn't get the old engine running, but you will be chasing leaks for a while
    My neighbor has a collector's edition '96 Vette with very low miles, but it's not a trailer queen. He's having been having a hard time selling it because it's not extremely low miles, but not enough miles to keep the seals and gaskets in good shape. I guess it sucks to be him Razz
    Post by G-Man Thu Nov 27, 2008 5:27 pm
    bluefever, give us some pic's when you get it.
    bluefever
    Post by bluefever Thu Nov 27, 2008 5:31 pm
    well i'm planning on going to see it early next week,so yeah i'll post some pics if i decide to get it.
    Number of posts : 1135
    Post by benwah Thu Nov 27, 2008 8:02 pm
    slant 6 - 20 years hmmm 1 can of starting fluid 1 fresh battery file the points fresh gas,as long as the fuel pump works shell run, might smoke like a train . that van is all there by the looks of things, good for parts .bringing this one back can be done ,but will take a while. people have started with worse.
    bluefever
    Post by bluefever Fri Nov 28, 2008 4:17 am
    should unless it's seized or it's too cold for it to want to start,but we shall see...
    Number of posts : 1388
    Post by wideload Fri Nov 28, 2008 4:46 am
    Welcome to the site bluefever. Good luck in you search.
    Post by itruns Fri Nov 28, 2008 5:01 am
    Also bring some carb cleaner, jumper leads, fuses, test light, brake fluid, motor oil, lots of trans fluid, funnel, diff oil, grease and antifreeze/water. The brake lines are probably shot, so STAND on that peddle before you go putting it in gear.
    Be sure to check out the rain gutters. Good luck.
    bluefever
    Post by bluefever Fri Nov 28, 2008 5:49 am
    do i really need all that just to turn it over and see if it'll run?also roughly how much would this thing weigh?it's obviously an extended version,i have a 95 chevy suburban 1/2 ton i just bought with the throttle bodied 350,do u think that's capable of towing it?
    Post by itruns Fri Nov 28, 2008 6:37 am
    No, you don't need all that to see if it fires. I'm just remembering when I got my parts van running in my shop. Got the engine running, put it in gear in the loading dock, no brakes. I thought she'd run over the 6x6s coming back down. A little scary. My thoughts are the carb is probably varnished up and an electrical connection or 2 may be corroded, king pins may be frozen, etc.
    The Suburban should handle it no problem. The uni-body vans are relatively light. Be sure to have a good receiver hitch set-up. I would use a car trailer.
    Post by Vanish Fri Nov 28, 2008 7:27 am
    itruns wrote:Also bring some carb cleaner, jumper leads, fuses, test light, brake fluid, motor oil, lots of trans fluid, funnel, diff oil, grease and antifreeze/water. The brake lines are probably shot, so STAND on that peddle before you go putting it in gear.
    I would take all these things and any thing else you can think of !!!!! when you get out there ... it's real Easy to be OUT GUNNED !!!!!!!!
    bluefever
    Post by bluefever Fri Nov 28, 2008 2:05 pm
    i figured these had a frame under them since they have a 1/2 ton axle,but there a unibody????
    Post by G-Man Fri Nov 28, 2008 2:31 pm
    Yes they all are unibody and you will want to look that over carefully. We are not trying you out of this van. Just making sure you get a good one to start. With these early's its best to get the best body you can from the start. It will save alot of time and even more money. They say the right van finds you and with our help maybe we can make the finding easier if this is not the one for you.
    Post by itruns Fri Nov 28, 2008 9:46 pm
    I'd bring the kitchen sink, but that's just me. Starter, sockets/wrenches, PB Blaster, torch, fire extinguisher, wire, jumper cables, dust off (turned upside down is freeze-it), etc.
    Trans may be drained from a bad seal. Mopars take ATF +3 or +4. Beware the possible left hand lug nuts on the driver's side.
    I can attest to the whole 'the van finds you' thing. I wish I could have found something a little cleaner, but I'm very happy with what I bought.
    Post by Guest Tue Dec 02, 2008 5:55 am
    Congrats! New body panels are available. Check out Mill Supply www.millsupply.com or Auto Body Specialties www.autobodyspecialt.com
      Current date/time is Mon May 20, 2024 5:34 am
