    auxillary radiator
    Number of posts : 890
    auxillary radiator Empty auxillary radiator
    Post by jrinaman Thu Sep 29, 2011 9:46 pm
    the previos owner had added a second radiator on the belly pan and connected it to the heater hoses. never thought much about it until going to nats. many others complained of cooling problems in there early chevies and g-man pointed out others could benefet from this mod. i have a 250 6 cylinder with bigger cam and higher compression and run 170 degrees almost all the time. i have towed a pop up camper and evan with breif runs at 85 mph, it would only go up on big hills. i had a th350 going to nats and it went just over 200 on big hills but dropped back to 170 by the bottom of hill. i since installed a 700r4 and have yet to pass 185 with the camper.auxillary radiator Disc_b10auxillary radiator Disc_b11auxillary radiator Disc_b12auxillary radiator Disc_b14auxillary radiator Disc_b13
    auxillary radiator Empty Re: auxillary radiator
    Post by G-Man Fri Sep 30, 2011 3:56 am
    Many of us looked at this set up at the Nats and everyone agreed he should keep it as is. This maybe the just the thing for guy's living in warmer areas
    Number of posts : 1605
    Post by itruns Fri Sep 30, 2011 5:10 am
    So, you have an electric fan in there too?
    Post by jrinaman Fri Sep 30, 2011 7:44 am
    auxillary radiator Disc_b15somehow forgot that pic. the fan was wired to a toggle switch when i got it. i have it wired to run when key is on and have a thermostat/switch i plan on installing.
    Number of posts : 801
    Post by panelmanrd Fri Sep 30, 2011 8:37 pm
    I often thought about doing that same thing,
    thanks for the info,and how well it works.
    Number of posts : 7900
    Post by DanTheVanMan Sat Oct 01, 2011 4:56 am
    jrinaman,
    Very interesting mod indeed! Very thought provoking! I often thought about remote mounting one underneath like some folks have for AC condensers but never got serious about it. Good to see and hear it does work.
    Dan
    auxillary radiator Qr_cod10
      Current date/time is Mon May 20, 2024 1:02 am
