+4
rustyspoke66
8 posters
new radiator
new radiator
anyone know were the best place to buy a radiator for my 68 108 318 automatic ? lucky to make it home it blew out a mile away, aluminum radiator would be ok also, thanks for any help
- Number of posts : 8732
Re: new radiator
John there is no direct bolt up aftermarket rad for the a100's call these guys tell them what you have and what want , 2 core 3 core 4 core , tranny cooler and so on they can fix you up, that is what i'm running, made in the U.S.A. http://www.fsrradiator.com/
Re: new radiator
thats what i'll do in the morning, thanks dix, we just got back from a nice long drive, i pulled in the garage and it blew a hole in it, thank god i didnt go to butler i would have been stuck,
Re: new radiator
You will never be stuck at butler, we will allways get something done. you would NEVER be left alone...
Re: new radiator
o i know that, my luck i'de be stuck out on the road, lol i wish it would have lasted a little longer tho, i'm going to remove everything this winter the rad. was on the list of things to do, i'll just get an early start on it now,,
Re: new radiator
Re: new radiator
Re: new radiator
dodge man Can yours be recored???? Then you won't have mod it
Re: new radiator
thats what i was thinking G-man if i dont get one from fsr radiator, i'll check with the radiator shop in steubenville maybe they can recore it, and i'll get a price on 3 cores that would be even better
Re: new radiator
Yes that is mine it was done at butler, i guess i need to make a post regarding this.
Re: new radiator
yeah put some pictures in it,,
Re: new radiator
WELL, I ORDERED ONE AT FSR RADIATOR FOR 470.00 THE RAD. SHOP IN MY AREA WANTS 560.00 TO RECORE MINE, THATS CRAZY, I THINK AN ALUMINUM ONE WILL BE MUCH BETTER,
Re: new radiator
Re: new radiator
JUST INSTALLED MY NEW RADIATOR FROM FSR, IT FIT PERFACT AND RUNS COOLER THAN EVER, THANKS DIX FOR TELLING ME ABOUT THEM, GREAT PEOPLE TO DEAL WITH 3 DAYS AND IT WAS AT MY DOOR, THE ONLY THING IT WAS 470.00 BUT WELL WORTH IT FOR A ALUMINUM RAD. THAT BOLTS RIGHT UP,
rustyspoke66- Number of posts : 180
Re: new radiator
Are you using a stock fan?
Re: new radiator
YEAH EVEN WITH THE OLD RADIATOR AND NO PAN TO GUIDE THE AIR IN, IT NEVER WENT PAST HALF WAY ON THE GAUGE EVEN WITH 80 DIGREE WEATHER, STOCK FAN AND 180 DIGREE THERMOSTAT,
Re: new radiator
I WOULD RECOMEND FSR TO ANYONE WHO NEEDED A RADIATOR, THEY HAD JUST WHAT I NEEDED, WITH THE PRICE OF COPPER, I SHOULD GET ALOT FOR MY OLD RAD.
Re: new radiator
Will you post the part number that FSR issued for that radiator?
- Post n°19
Re: new radiator
145100 it fit perfect in my 68 A108 318 it would be the same # for a A100
- Post n°20
Re: new radiator
Perfect, I have a 67 A108 that will be losing the /6 for a V8 soon.
Thanks
Thanks
- Post n°21
Re: new radiator
when you call ask for bill, tell him what you have he'll fix you up, very nice people, and fast service
sweetvan- Number of posts : 242
Registration date : 2013-12-16
- Post n°22
Re: new radiator
I need to repair or replace my radiator in my '65 A100, 273, automatic too and I don't have a service manual. Do I take the front "dog house" engine cover off with the radiator in it and then take the radiator out of the cover? Are any of you using an overflow tank that fits next to the radiator inside the front cover? It looks like there might be room. What pressure does the new aluminum radiator operate under? What type of a cap are you using, e.g. 7 pounds with a pressure release lever? Did the price quoted include shipping? Any recommendations for shops near Ventura, California?
Thanks, Sweetvan.
Thanks, Sweetvan.
- Post n°23
Re: new radiator
Well as for pulling there are four bolts attaching the radiator to the radiator frame (front housing), they screw in from the front, two on each side. I dropped the radiator from the bottom.
- Post n°24
Re: new radiator
Yep out the bottom A frs rad will come with a cap about 16 lbs. and i'm running a over flow.
https://www.google.com/search?q=overflow+bottle&tbm=isch&source=iu&imgil=iQ2dyAdDntOMVM%253A%253Bhttps%253A%252F%252Fencrypted-tbn1.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcS6DgkOhbBeitbkvQ5AzqkEFTscOc_cQEqD66Bq22J3NYyUK1wXiA%253B640%253B480%253BGlW9X3r2tP9oAM%253Bhttp%25253A%25252F%25252Fwww.speedzilla.com%25252Fforums%25252Fhonda-rc51%25252F46875-coolant-overflow-bottle.html&sa=X&ei=WkW_Us6BKuzgsATR64HQDQ&ved=0CE4Q9QEwAQ&biw=1344&bih=678#facrc=_&imgrc=iQ2dyAdDntOMVM%3A%3BGlW9X3r2tP9oAM%3Bhttp%253A%252F%252Fwww.speedzilla.com%252Fforums%252Fattachments%252Fhonda-rc51%252F15002d1207607878-coolant-overflow-bottle-dscf0004.jpg%3Bhttp%253A%252F%252Fwww.speedzilla.com%252Fforums%252Fhonda-rc51%252F46875-coolant-overflow-bottle.html%3B640%3B480
- Post n°25
Re: new radiator
if you do go with a new one its worth the money for a aluminum one from four seasons radiator {fsr} they have all the measurements of the one you need,
