I was Just wondering .. Do Headers always Leak ??? or Did I do something wrong ?? When I have Had Headers in the Past they Have always Leaked .. and when I went Back to stock exhaust .. with the Little Clips on the Manifold .. Never had another Problem .... was I doing something wrong ??? Or is it Just Part of the Deal ....
Do Headers always Leak ????
Vanish- Admin
- Number of posts : 5155
,,,Vanish,,,
MCMLXV
Re: Do Headers always Leak ????
I always used either copper gaskets or "metal weave" gaskets and never had a problem with them leaking at the head. Tighten them up, then tighten them again about once a week for a month or so (just a little) to compensate for gasket compression and they tend to last a good long time.
I plan on using them again on my next engine build and will probably use aircraft wire on the bolt heads.
[i]The hedders will leak -usually because the owners never take time to tighten the bolts up - this is due to shrinkage of the gasket due to heat. This is an on going problem & must be checked- there are many different gasket types also = as mentioned above - also some different types of headder bolts - and there are locking types- Id suggest emailing the builder of your specific brand headders & asking them about the problem & what they suggest for a fix?? also =if you have added some lock washers on the headder bolts =take them off as heat will make the locks not work due to heat - and then you will have the bolts loosen & blow out the gaskets = Happy Vannin
You normally have to tighten them 3-4 times.
63chevyvan?- Number of posts : 125
I use stock OEM manifold gaskets with headers..........no leaks.
63
63
