After some searching and not finding the answer I was looking for I am posting my question. My front doors need new pins/bushings, which does it need, part numbers, and who has done it?
Those hinges are probably worn out and you might need to drill it out and install the next oversized bushings,,,,,,and this is how I do Chevys,,,,you might take apart your hinge and see if these Dodge bushings will work,,,,,,,
