    Got a Question ....
    Got a Question .... Empty Got a Question ....
    Post by Vanish Wed Aug 17, 2011 6:25 pm
    This is the Back side of my Motor .... I believe this was a Stick .. I'm putting an auto Trans in My Van .. Dose this Plug Need to be removed from the crank for The C4 auto Trans ???
    Got a Question .... Cid__Photo080-vi
    eric67vanpkup
    eric67vanpkup
    Number of posts : 85
    Registration date : 2010-12-07
    Post by eric67vanpkup Thu Aug 18, 2011 9:39 am
    That is the pilot bushing. You will have to remove it so the shaft on the transmission slides into the end.
    Eric. MS
    Got a Question .... Empty Re: Got a Question ....
    Post by Twinpilot001 Thu Aug 18, 2011 10:03 am
    Yes -Ditto- slide hammer or if can be maybe compressed air or grease filled hold & round stock that fits the hole - forcing the bushing out
    SDEconoTruck
    SDEconoTruck
    Number of posts : 310
    Post by SDEconoTruck Thu Aug 18, 2011 10:07 am
    No transmission shaft, he's using a C4. The torque converter usually slips into that larger hole or the hole of the flexplate depending upon specific set-up. Good idea to remove the pilot bearing usually nothing will go into the hole but this depends upon the type of converter you have for your automatic. Check the front of your TC...
    George
    cl350rr
    cl350rr
    Number of posts : 287
    Post by cl350rr Thu Aug 18, 2011 12:41 pm
    if ya gotta remove a pilot bushing, fill the hole in it with small pieces of wet paper towel or tissue. pack it full of them... take a shaft that just fits in the hole, push the shaft in and hit the end with a hammer. hydraulic action will push the bushing out of the hole. it will take several hits with the hammer.
      Current date/time is Thu May 02, 2024 4:53 am
