What is every one using for a over flow bottle ??? and where did you mount it ??? also what thurmostate do you run. i am trying to get the heat down....i already have a new alluminun rad, and no shroud. thanks guys.....
+4
8 posters
OVER FLOW BOTTLE
- Number of posts : 8731
OVER FLOW BOTTLE
Re: OVER FLOW BOTTLE
Im just running a cheap looking thing I picked up for 5$ ata yard sale ,similar to the plastic one Gman is showing. I think you just want to mount them so the fill is below the main water sytem fill ? Im running a 185 stat but am considering dropping it down a couple notches to the 165 area. I accidently cured my high speed overheating by dropping the radiator 3 inches to put the seats in. I want to see if I can get the run temps down with a colder thermostat now.
i'm going to try a 165 stat today and then work on a shroud. i'm sure every thing will help...
m1dadio- Chevy Guru
- Number of posts : 1778
you could use an old Jack Daniels bottle or something cool like that
m1d
m1d
Just make sure that JD bottle is empty!! 1ST.
I'm using a Doorman "Coolant Recovery Tank". it costs $7.50 and I mounted mine right to the doghouse.
63chevyvan?- Number of posts : 125
Jegs.com
PN# 821-7040D
63
PN# 821-7040D
63
gotavan- Number of posts : 242
This came from a yard sale years ago haven't used it yet.
That would be the =BEST!!
rat rod from a local car show:
JD overflow bottle, Pressure Cooker air cleaner housing.
