I was wondering if any One here with a Big 6 or V8 Crossmember has Put spacers between the crossmember and the unibody to Drop the motor Down ??? if so Do you have pictures of it ??? Thanks' ...........
Engine .... Crossmember .....
Vanish- Admin
- Number of posts : 5155
,,,Vanish,,,
MCMLXV
Re: Engine .... Crossmember .....
In past posts there are fotos and xmember pics of same install
Vanish- Admin
I was thinking there was also .... Cant seem to find any thing on this ..... I have seen chevys done this way !!!!! I am thinking that if I drop the motor down I can get a better Drive line angle ..... Looks Like You would have to go with 4 Blocks on a Ford !!!!!!
,,,Vanish,,,
MCMLXV
drop was 2" and same for xmember - with 700r4 as i remember?seems was dadio1 or??
Hellfish- Number of posts : 146
There are 2 articles scanned and posted here. I think the 2nd one shows a drop. Why do you want to lower the motor?
http://www.wingsisp.com/emboss/econo.htm
Vanish- Admin
Hellfish wrote:There are 2 articles scanned and posted here. I think the 2nd one shows a drop. Why do you want to lower the motor?
I am Looking for better Drive Line angles !!!!!
,,,Vanish,,,
MCMLXV
hey vanish - is this for the 4 x 4 van??
Vanish- Admin
Twinpilot001 wrote:hey vanish - is this for the 4 x 4 van??
That's the One !!!!
,,,Vanish,,,
MCMLXV
likely - will need more drop @ the tranny mount?? maybe even a carb adapter for the angle? Like on the old imboard marine engines? Just thinking?
Float levels?
Float levels?
