I need HELP!
I have this huge list of repairs that I need to fix so that my Old Girl can pass Provincial Vehicle inspection, hoping you all can help me with info and suggestions.
1969 G10 350 ci with a turbo 400 trany
1 - Marker lights, when I removed the lens I found there is no wiring. Not even a hole from the body to the front door for a wire to pass through. ** I thought the 69 came with working marker lights or was it just an option??
2 - Back up lights, I can't find a switch. ** Where should I look for the switch??
3 - Passing gear kick down switch, same thing can't find it where should it be??
4 - Neutral Safety Switch, not sure were to look. Where is the switch suppost to be on a 1969 turbo 400??
If you know the answers to any of these question, I need to hear from you.
Thanks in Advance
Thanks in Advance
