+6
jdlaugh
gfleduc
10 posters
Broken bolts
samsvan- Number of posts : 672
Broken bolts
I noticed that a bolt was missing from my alternator bracket and it had a crack in it. I went ahead and pulled the whole thing out to switch it out. Now I see that there are two bolts broken off in the block. They are both 5/16 grade 8 bolts. Of course they are hard to get at so I was thinking about trying to weld an old screwdriver to the bolts to pull them out. I tried drilling them to use an extractor but no luck. I can't drill straight in because the balancer is in the way. Am I screwed or what?
Scott- Number of posts : 1651
Re: Broken bolts
If there is any bolt sticking out with threads you can put two nuts on it and back them into each other. You would have to be pretty good to get a screwdriver welded on there, and that weld would have to be pretty good to take the pressure it needs to loosen the bolts. Well, unless they are not very tight.
You might just have to bite the bullet and pull the balancer. Pain, but if it gives you the needed room to drill straight.
gfleduc- Number of posts : 367
Broken Bolts
Well if you are good with a welder - I suspect TIG - It is a common practice in industry to remove broken bolts by the method - commonly they weld a bolt on so you have something you can torque with.
As a prep it is good to soak it a while with a pure penetrant - then of course clean it.
Let it cool because the bolt will be the hottest & you would otherwise also be fighting thermo expansion.
Re: Broken bolts
Similar , make a half nut and try welding that on with a MIG. Or take a strip of thicker sheetmetal , drill a hole the same size or slightly smaller and weld that on and tap it with a hammer to get it loose. I have done that a lot with flush broken bolts from exhaust manifolds to bumper bolts.
Re: Broken bolts
Re: Broken bolts
oh sweet, great idea
Broken Bolt
Nice! - good for you...
Re: Broken bolts
^5s
Re: Broken bolts
Re: Broken bolts
I'v been hearing my serpentine belt squeaking a little lately and then today, I noticed a lot of vibration when I was idling in gear, like at a stoplight. Turns out it was the same two bolts were broken off again. What would be causing this much stress? My motor is a '92 350 TBI and the only thing not stock is that we re-located the alternator down where the power steering pump used to be so it would clear the doghouse. There is no visible movement when I first bolt it together so whatever is happening takes a while to break the bolts. Any ideas?
Re: Broken bolts
Could be the pulley is not exactly in-line with the serpentine system. That would cause a squeaking belt and put stress on the bolts.
- Number of posts : 12218
Re: Broken bolts
Are the bolts too long and bottom out so that they are not holding the alternator on REALLY tight? you using grade 8 bolts?
Re: Broken bolts
JD, I can't say for sure that everything is factory perfect but when I put a straight edge across the pulleys, they look in line. And Don, luckily the bolts aren't bottomed out. That at least makes them easier to get out. I am using grade 8 bolts and that made me wonder if using regular ones would allow them to stretch a little.
Registration date : 2011-03-11
Re: Broken bolts
do you have a rear brace? while this may not fit your needs, you could likely find one that does or make one. https://www.lsxinnovations.com/product/ls-truck-low-mount-alternator-bracket-w-pulley-rear-brace/
Re: Broken bolts
Re: Broken bolts
i had to make a braket that bolts to the rear of the alt that went over
to the motor mount bolt this stops the vibration of the alt and the broken
bolt thing went away
Re: Broken bolts
I actually looked at those ICT brackets but there was some reason I didn't think it would fit. I guess making one is what I'm going to have to do. It looks like so much fun under there, I can hardly wait!
BILL Carson- Number of posts : 171
Registration date : 2011-05-02
drill
Thay do have an angle drills to do that
- Post n°19
Re: Broken bolts
- Post n°20
Re: Broken bolts
- Post n°21
Re: Broken bolts
- Post n°22
Re: Broken bolts
mine was very similar but i used one of the bolts at the block
where the motor mount bolt to, sometimes that bolt shown
in the pic is challenging to install due to alignment issues
- Post n°23
Re: Broken bolts
should stop the broken bolt issue
- Post n°24
Re: Broken bolts
Ha! Tell me about it. My wife had to make the kids stay inside for this one.
Thanks for spinning the picture Vanny. You're a gentleman.
- Post n°25
Re: Broken bolts
when i was about 8 years old, my mom suggested
to my dad that he take me with him golfing one sat
that was the day i learned how to swear. profusely
