    Rebuilding the motor. Jeez.
    Number of posts : 437
    Registration date : 2010-12-14
    Rebuilding the motor. Jeez.  Empty Rebuilding the motor. Jeez.
    Post by StuNami Sat May 07, 2011 2:37 pm
    I ordered all of my motor parts, pistons, rings.. etc. a month ago. Just got it ready to put everything in and wrong stuff. Shoulda decoded the block first. 67 HD should have 240 in it. I have a 1979 3.3. or 200 from a Mercury Zephyr. That would explain the dura spark electronic ignition. That's cool though, parts exchanged and will be here Tuesday. Completely rebuilt the 3 sp and just need to find the right input shaft seal. Got 2 others coming Monday though.
    So far the 9" has all new gears and bears as does the tranny. Motor coming. Off to body shop by next weekend if no burps. Hope to reveal the new van at Baker's so no pics yet. I have em to cronicle the build though.
    Number of posts : 2198
    Rebuilding the motor. Jeez.  Empty Re: Rebuilding the motor. Jeez.
    Post by EconoUSAparts Sat May 07, 2011 3:26 pm
    For the record,a 67 HD was available with a 170 also. I just got rid of a 66 HD 170. The HD pkg was basically frame and undercarriage components and had nothing to do with the motor itself as odd as it may seem.
    Post by EconoCarl Sat May 07, 2011 4:00 pm
    Have you decoded the VIN?
    A lot of info to be had there.
    Post by StuNami Sat May 07, 2011 5:55 pm
    Yeah, I decoded it Thursday and it came back as a 1979 mercury zephyr 200 motor. It was a pretty strong motor when I pulled it but needed some seals and soft plugs and I couldn't stop there.
    Tim,
    Yeah I just assumed HDs had 240s never woulda thought a 170 would be a good match.
    Post by EconoUSAparts Sat May 07, 2011 5:59 pm
    The first HD models came out in late 63 and the 240 wasnt available until 65. Even some of the Supervans had the 170 in it.
    organ grinder
    Number of posts : 149
    Post by organ grinder Sun May 08, 2011 1:16 am
    StuNami wrote:Yeah, I decoded it Thursday and it came back as a 1979 mercury zephyr 200 motor. It was a pretty strong motor when I pulled it but needed some seals and soft plugs and I couldn't stop there.
    Tim,
    Stu,
    I think Carl was asking if you decoded the VIN # of the van? That would tell you the size of engine it originally came with. Of course it doesn't matter now, it would just be for your info. But would also tell you info about the tranny, rearend gearing, if it's a true HD and so on....Like Carl say's, there's a lot of info on the VIN and data plate.
    OG
    Post by StuNami Sun May 08, 2011 5:52 am
    Oops. I don't read too well after a little partying on a Saturday evening Wink Yeah just read it again. I did decode that when I got it. It did have a 240 originally that's why I bought all the parts, with a 9" 456 gear. Assemblend in ohio and olive green paint. The gear had already been changed, it had a 330 when I pulled it out last month.
    Number of posts : 864
    Post by Casimier Mon May 09, 2011 12:09 pm
    So Stu...
    what you doin with those 3:30 gears?
    Might work good with my 300.
    Jim
    Post by StuNami Mon May 09, 2011 5:24 pm
    Hey Jim,
    I didn't even keep them. Both the ring and pinion where ground pretty good. I had you in mind when I took them out but they def were not good.
    Post by Casimier Tue May 10, 2011 5:41 am
    thanks for the thought...this site is great!
    Everyone looks out for one another.
    Post by StuNami Tue May 10, 2011 6:45 am
    Yep, and I look forward to meeting you at Carlisle
      Current date/time is Tue May 07, 2024 2:53 am
