    Rebuilding inner rockers
    Hellfish
    Number of posts : 146
    Rebuilding inner rockers Empty Rebuilding inner rockers
    Post by Hellfish Mon Apr 30, 2012 11:06 am
    Does anyone have any photos of the right side inner rocker at the rear by the rear wheel? I don't know if it will tell me anything, but I'm trying to rebuild the door frame (side doors) on my '65 and it's pretty much shot. There was not enough of either the pillar/brace or rocker below the floor for me to even start patterning, so I'm working blind here.
    Here's what I have (after I cut out the floor)
    Rebuilding inner rockers IMG_8640
    Rebuilding inner rockers IMG_8692
    And after rebuilding parts of the floor and outer rocker. You can see the lip/seam where the fender and rocker meet. The fender is a little twisted at the end.
    Rebuilding inner rockers IMG_9172
    Rebuilding inner rockers IMG_8894
    Rebuilding inner rockers IMG_8883
    Rebuilding inner rockers IMG_8880
    I think the pillar needs to extend all the way down like the other side, but it seems like it would straddle the fender/rocker seam, which doesn't seem right and wouldn't match the other side (although I know these vans are not symmetrical)
    Here's what that other side looked like before/after I rebuilt the braces, before I welded in the inner rocker.
    Rebuilding inner rockers IMG_8638
    Rebuilding inner rockers IMG_8693
    Rebuilding inner rockers IMG_8871
    Rebuilding inner rockers IMG_8827
    66ThunderVan
    66ThunderVan
    Number of posts : 384
    Rebuilding inner rockers Empty Re: Rebuilding inner rockers
    Post by 66ThunderVan Mon Apr 30, 2012 1:12 pm
    Good job!
    66ThunderVan
    66ThunderVan
    Post by 66ThunderVan Mon Apr 30, 2012 1:17 pm
    PS, I will try to take some pics of mine for you.
    Hellfish
    Post by Hellfish Mon Apr 30, 2012 1:52 pm
    Thanks, and thanks! This is my first attempt at this kind of repair. I'm going to do a full rebuild post once I'm closer to done. You're only seeing the tip of the iceberg in these photos.
    Number of posts : 2198
    Post by EconoUSAparts Tue May 01, 2012 3:19 am
    I have a complete rear corner section that includes a foot of the rear roll pan forward including rear corner,wheel well panel,and upper window panel,forward past the side door opening. It includes inboard to the frame rail including the frame rail so in other words it has everything you need to fix yours. I could haul it to you on my way to the Nats in Wisconsin in July.
    Hellfish
    Post by Hellfish Tue May 01, 2012 7:19 am
    Thanks, Tim, but I'm hoping to have this back on the road by June. Smile Besides, other than that pillar, the rest of that side is in good shape. Oddly, so was the other side other than the braces and inner rocker panel, and a portion of the corner by the roll pan. I was completely missing the roll pan, but one is on the way from Dennis.
    HOWEVER, if your section includes the barn door rear pillar, I'd LOVE to see a picture of it. Smile
    Post by EconoUSAparts Tue May 01, 2012 6:34 pm
    Yes it includes the rear and side door pillars in perfect shape. I looked tonight and I cut the section about 2 inches inboard of the wheel well so the whole well is included also.
    Hellfish
    Post by Hellfish Wed May 02, 2012 7:10 am
    Could you post a pic? It might help me in reconstructing mine.
    mothradeath
    mothradeath
    Number of posts : 217
    Post by mothradeath Thu May 03, 2012 7:08 am
    i dont have a pic for you because i cut all that stuff out awhile ago but i can tell you FOR SURE that those verticle pillars are not matching per side. not symetrical.
      Current date/time is Sun May 19, 2024 6:18 am
