    Halogen sealed beams
    Number of posts : 437
    Registration date : 2010-12-14
    Halogen sealed beams Empty Halogen sealed beams
    Post by StuNami Fri May 06, 2011 1:26 pm
    Any issues replacing the sealed beams with halogen sealed beams?
    ~Nami
    Number of posts : 3046
    Halogen sealed beams Empty Re: Halogen sealed beams
    Post by RodStRace Fri May 06, 2011 2:01 pm
    There should not be. I researched this for my 1940 Plymouth.
    They are more efficient so although they put out more light, they use the same amperage.
    This applies to the halogen bulbs that are not sealed beams too.
    Here is an example
    http://www.jeep4x4center.com/jeep-lighting-parts/hella/halogen-headlamps.htm
    I would suggest that when you replace them that you clean all connections especially the grounds. Kind of a good thing to do on all electrical stuff.
    Number of posts : 7900
    Post by DanTheVanMan Fri May 06, 2011 3:09 pm
    I have them for my 66 Panel. Direct replacement and they work great...
    Dan
    Halogen sealed beams Qr_cod10
    Post by StuNami Fri May 06, 2011 3:40 pm
    Cool Thanks guys. Any experience with putting a dummy load resistor in for led taillights? Looks simple but an electrician I am not and I still remember what early van wires smell like when they burn even though that 30 years ago Wink
    Post by EconoCarl Fri May 06, 2011 5:22 pm
    When I went with LED taillights, all I had to do was replace the turn signal flasher with an electronic one. Any of the chain auto parts stores should have one.
    Post by DanTheVanMan Fri May 06, 2011 5:37 pm
    Halogen sealed beams 67551710
    Post by StuNami Fri May 06, 2011 6:07 pm
    crowen57 wrote:When I went with LED taillights, all I had to do was replace the turn signal flasher with an electronic one. Any of the chain auto parts stores should have one.
    I was going to buy one and the guy at speedway said the resistors work better. Maybe they work better for his profit margin?
    I have a 67 and the flasher is different than on my 65. My flasher looks like a horn relay. It has a metal casing and bracket and is fastened to the firewall. Did you have one like that? I've seen the led flashers for 10 bucks.
    Post by EconoCarl Fri May 06, 2011 8:25 pm
    My '67 had the large 2 wire flasher 'box' also. Seems like I had to make a jumper/adapter wire to hook up the electronic flasher in place of it. When I yanked the LED bulbs from the '67 and put them in the '66 I forgot to change the flasher and they wouldn't blink.
    Post by StuNami Fri May 06, 2011 9:30 pm
    Thanks. I think I'll get a flasher and send back the resistors when they get here. I'd have to think that the resistors would get a bit warm
    DanTheVanMan wrote:Halogen sealed beams 67551710
    Thanks Dan.
    Post by StuNami Fri May 06, 2011 9:32 pm
    RodStRace wrote:There should not be. I researched this for my 1940 Plymouth.
    Here is an example
    Thanks. I've been cleaning connections. Brake light switch and others were getting a bit corroded too.
      Current date/time is Tue May 07, 2024 6:21 pm
