Do you guys rebuild your fuel pumps on the 170's or just replace them, if you rebuild them where do you find rebuild kits?
elmonto
bumpbug
170 FUEL PUMP
bumpbug- Number of posts : 147
170 FUEL PUMP
toad- Number of posts : 355
Registration date : 2010-05-30
Re: 170 FUEL PUMP
I bought mine new from Autozone.
Re: 170 FUEL PUMP
was just wondering if there was rebuild kits or just replace the dam thing.
Re: 170 FUEL PUMP
For what they cost, I'd just replace it. Not sure if kits are even offered.
http://www.autozone.com/autozone/parts/1965-Ford-E100-1-2-ton-Van/Fuel-Pump/_/N-iype5Z8vcz2
elmonto- Number of posts : 56
Registration date : 2010-07-09
Re: 170 FUEL PUMP
Ya they are cheap, most parts stores stock them.
sunnskate- Number of posts : 120
Re: 170 FUEL PUMP
Thats a good time to change out the old fuel lines to. and the filter.
Re: 170 FUEL PUMP
OK Guys - ive got to replace my fuel pump also same as this one - what i need is some fotos of the origional filter & line setup from pump to carb-anyone - mines gone =Thanx
Re: 170 FUEL PUMP
Thanks everyone, just thought I could save a little money to put towards something else. Looked rebuild able but a new one it will be.
LVMtnMan- Number of posts : 30
Registration date : 2013-05-05
Re: 170 FUEL PUMP
Has anyone converted to an electric fuel pump?
Old Skool- Econoline Guru
- Number of posts : 1306
Re: 170 FUEL PUMP
That is all I use as I think the mechanical pump puts out too much pressure. Ours needs a maximum of 4 psi.
vic
vic
