I need a radiator for my v8 swap. I see a lot of guys used Reliable Radiator.
I am putting a 302 sb from an '87 Mustang into my '63 Econo Pick up. The water outlets on the motor are, top pass side bottom drivers.
Has anyone done this swap and have a particular radiator they used?
Not sure if I should go with a three or four core? Should I look at the Econo Rad's or the Mustang rad's?
Do they make Econo rad's with the water outlets the way the motor is set up?
Thanks
Donn
Thanks
Donn
