jkr wrote:are the springs you used the same ones that were on the van???
were they something from a salvage yard,or
are they something you bought and were told were correct.
the reason i ask is i can't see how flipping the rear shackels move the centerline that much forward and change the pinion angle that much.
the van MUST have had shims and they did not replace them.
My springs are EOM, they just reversed the shackles by mistake. Letting the shackles hang "down" raised the pinion angle by about 3" and that was too much, the rear U joint couldn't take it. Putting them back "up" got the pinion angle back where it needed to be, now the vibration is gone. My van had no shims in the rear, the shop just let the new guy finish the job and he goofed it putting ti back together.
The A100 shop manual is the ultimate reference here, no more than 6 degrees total variance across the drive shaft (from trans to rear yoke) is what Ive gotten from the local off road shop (who deals with lift kits all the time).
