    1966 sportsman engine swap. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!?
    1966 sportsman engine swap. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!? Empty 1966 sportsman engine swap. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!?
    Post by Guest Sat Mar 05, 2011 10:22 pm
    my new crate motor sits at a nasty slant towards the front? old motor was a 1973- 318 which had a smaller slant. i dont think my oil pick up is getting enough oil? because of the slant?
    new motor is a 1979 -318
    Last edited by timleshark1 on Sun Mar 06, 2011 2:42 am; edited 1 time in total (Reason for editing : wrong info)
    1966 sportsman engine swap. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!? Empty Re: 1966 sportsman engine swap. HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!?
    Post by Guest Sat Mar 05, 2011 10:24 pm
    ps i believe the casting on the passenger side of the motor states that it is a 1979
    318. did they send me the wrong motor?
    Post by G-Man Sun Mar 06, 2011 4:14 am
    Welcome to the site!!! You'll have more chances of people who know seeing this if you post in Between the seats "A"
    Number of posts : 8731
    Post by dix Sun Mar 06, 2011 5:59 pm
    CAN YOU GET US SOME PIC'S??? WHAT ELSE DID YOU CHANGE?? YOU ARE RIGHT IF THE MOTOR IS SITTING ON A TILT YOU WILL STARVE THE ENGINE OF OIL . THAT IS NOT GOOD. IS THERE ROOM TO RISE THE FRONT UP TO GET IT LEVEL???
    Number of posts : 3046
    Post by RodStRace Mon Mar 07, 2011 7:26 am
    Motor brackets go behind the engine ears. Motor mounts then frame brackets.
    WP nose should be centered in the fan shroud.
    Transmission mount should have the bolt go through the center.
    Don't know how you could end up with the motor nose down unless the parts or the combo are wrong. Please take pictures, host and post....
      Current date/time is Tue May 07, 2024 6:56 pm
