Am i missing a nut?
peter73- Number of posts : 3
Registration date : 2010-10-15
Am i missing a nut?
Re: Am i missing a nut?
jkr- Number of posts : 1148
no nut needed but you do require another spring by the look of things
You mean the spring that is hanging down?
I took it of bescause i removed the oil pan and things there.
That nut adjusts the clutch,,,,,that arm going into the bellhousing operates the throwout bearing. That arm should not be tight against that rubber washer with the spring off if the clutch is adjusted correctly. Then that return spring holds the arm against the washer.
