Temp window reg fix..
Bear- Number of posts : 849
Re: Temp window reg fix..
first gen or 2nd gen regulator ?
gotavan- Number of posts : 242
The one in the picture looks like a 1968-70, they have the bigger shaft and the slot for the handle clip. The 1964-67 shafts are smaller and use a set screw in the handle. Usually the gear teeth are worn where the window is up and need welding to fix them. the part where the shaft is should be packed with light grease.
Yes it's second gen.
i think i have afew of them
