BADBADGER
    318 engine install?
    BADBADGER
    BADBADGER
    Number of posts : 246
    318 engine install? Empty 318 engine install?
    Post by BADBADGER Mon Feb 07, 2011 5:07 pm
    The engine was out of the van when I recd it. I'm getting close to putting in the rebuilt 318 and 727 trans. Acouple of questions:
    1. Do I install the front of the dog box with radiator support first, or install it after the engine is in.
    2. Does the engine install thru the bottom of the engine compartment? It looks like it would go in that way with trans attached. I have the room and capability of getting the van high enough.
    Any other suggestions?
    Number of posts : 1148
    318 engine install? Empty Re: 318 engine install?
    Post by jkr Mon Feb 07, 2011 5:36 pm
    you could do either. if the engine goes in from the top its easier with the front section out of the way. by the book the engine does come out from the bottom with the trans still attached.
    69 a 100
    69 a 100
    Number of posts : 142
    Registration date : 2009-01-03
    Post by 69 a 100 Mon Feb 07, 2011 7:18 pm
    i had the front of the dog house in and went through the side doors with out the trans then put the trans in from the underside
    BADBADGER
    BADBADGER
    318 engine install? Empty 318 engine installed successfully!!
    Post by BADBADGER Thu Feb 10, 2011 9:42 am
    Thanks for the comments on the opening of this post. Installed the engine and trans yesterday afternoon single handed. Used an MC jack and floor jack. Jacked up the front end and used 6X6's along with the jack stands to get the height. Slid the engine and trans underneath the side of the van then lowered the van over the engine (front wheels off). Took abit of jockying but it bolted up with out a hitch. About three hours give or take.
    moparhead340
    moparhead340
    Number of posts : 85
    Registration date : 2010-12-01
    Post by moparhead340 Fri Mar 11, 2011 4:56 pm
    badnadger when you did this, did you have to take the axle off?
    kltcustoms
    kltcustoms
    Number of posts : 199
    Registration date : 2008-07-07
    Post by kltcustoms Sat Mar 12, 2011 7:08 am
    When I changed my motor out we took it thru the side doors ..... Yes leave the doghouse completely out for all of the room you can get. Here are pictures of my shade tree motor removal.
    318 engine install? Motoro10
    318 engine install? Motorr10
    318 engine install? Cleane11
    moparhead340
    moparhead340
    Post by moparhead340 Sat Mar 12, 2011 11:26 am
    well on my new no door i dont get the privilege of having 4 extra doors to work with lol
    kltcustoms
    kltcustoms
    Post by kltcustoms Sat Mar 12, 2011 5:25 pm
    Yeah it is rather airy.....
    white-lightning
    white-lightning
    Number of posts : 237
    Post by white-lightning Sat Mar 12, 2011 5:45 pm
    My dad made a upside down square "u" with horizontal feet that sat in between the front wheel wells. He attached a manual winch to it to pull the engine up to disconnect the mounts and lowered the engine and transmission on to a heavy metal pan with rollers and rolled it out from underneath. He left the radiator in place, but removed the rest of the dog house. This was down 17 years ago so I don't remember the details.
      Current date/time is Tue May 14, 2024 10:50 am
