    engine cover
    engine cover Empty engine cover
    Post by Guest Wed Oct 15, 2008 12:22 pm
    hello all
    please forgive the stupid questions but this all new to me so i'm being extra cautious. i am taking off the dog house for a little clean up. couple questions:
    -can i unbolt the radiator bracket without compromising its support?
    -are there seals that i can get for between the floor and the bottom of the doghouse. and then also for the cover.
    -can i insulate the inside of the doghouse and cover to cut down on noise, heat, and possibly smell
    -and lastly what should i use to remove glue and rubber left from old weatherstripping
    thanks
    matt
    engine cover Empty Re: engine cover
    Post by Guest Wed Oct 15, 2008 3:57 pm
    I usually use a foam self-adhesive tape to seal the box to the floor. You can use Goof-Off or even brake clean to get the old glue off.
    I use this stuff to insulate the dog box.
    http://store.summitracing.com/partdetail.asp?autofilter=1&part=THE%2D14120&N=700+4294923429+4294923290+4294845359+400356+115&autoview=sku
    Post by Guest Thu Oct 16, 2008 6:39 am
    great thanks nate
    Post by Guest Wed Nov 12, 2008 12:34 pm
    There is a guy on ebay that sells the rubber gaskets for Chevy, Dodge and Ford doghouses.
      Current date/time is Sat May 18, 2024 5:05 pm
