    Rearend Gearing list.
    Number of posts : 7900
    Rearend Gearing list. Empty Rearend Gearing list.
    Post by DanTheVanMan Tue Jan 11, 2011 6:12 am
    Hmm: Think I'll start a list. What have you found?
    Stamped = Gear Ratio
    9-37 = 4.11
    11-37= 3:36
    Rearend Gearing list. Qr_cod10
    Rearend Gearing list. Empty Re: Rearend Gearing list.
    Post by DanTheVanMan Tue Jan 11, 2011 6:46 am
    Found this:
    Ratio............................ Teeth
    3.08............................40-13
    3.42............................41-12
    3.73............................41-11
    4.11............................37-9
    4.56............................41-9
    4.88............................39-8
    5.13............................41-8
    Post by donivan65 Tue Jan 11, 2011 9:09 am
    The 3.08 was 12-37.
    Post by DanTheVanMan Tue Jan 11, 2011 9:55 am
    Hmmm. Guess that's why I'm asking.
    Found a lot of contradicting info out there and having only dealt with a few different rear ends my self I thought I'd ask our members since we all have a rather "Hand's-On" approach..
    Thanks Don
    Anyone else care to share what they have?
    Post by donivan65 Tue Jan 11, 2011 10:26 am
    I am thinking that the capacity and size would determine the actual number of teeth in a rear end,,,,,,,but if we are talking Vans, the 3:08 was 12-37. But they are really rare, like maybe only in the 1970 vans,,,,unless someone installs one from some other kind of vehicle.
    Post by DanTheVanMan Tue Jan 11, 2011 11:36 am
    Good point. Guess I'm really interested in those different gears that fit our stock housings.
    Post by donivan65 Tue Jan 11, 2011 1:01 pm
    And those housings come in 2 flavors,,,,,,,,the 3:08 and 3:36 have the 10 bolt covers while the 3:73 and 4:11 are 12 bolt.
    Eagle1
    Eagle1
    Number of posts : 144
    Registration date : 2010-09-18
    Post by Eagle1 Tue Jan 11, 2011 1:08 pm
    Mine is 11-37....3.36 10 bolt cover
    Rearend Gearing list. IMG_7676
    Post by DanTheVanMan Tue Jan 11, 2011 1:18 pm
    Hmmmmm.... Reason being, I'm getting ready to drop the 327 & 2004R into the panel and haven't really addressed the rearend gear ratio yet. The rear in the 65 "Monster" panel parts van was out of a 69 Camaro with a POSI & 3:90 gears. Or so I was told. Have not cracked the case yet. But trying to get an idea of what to expect with this combo.
    Post by Digz Tue Jan 11, 2011 2:22 pm
    should be okay for hole-shots and a bit stiff for 70mph highway with the tires ya got. http://www.corral.net/tech/gearcalc.html It'll be quick !
    Post by DanTheVanMan Tue Jan 11, 2011 3:13 pm
    Thanks guys. Joe, that's a cool little ratio calculator... Very Happy
    Not looking to set any land speed records with this shoe box. Just trying to figure how it will travel long distance...
    And with the O.D. ratio being .65, 70mph should be ok, (Wind shear a side of course!)
    Post by Guest Tue Jan 11, 2011 6:17 pm
    Man.....Ester is hummin at 70, 4.11 12 bolt with a 700R4. 65 is better sounding, but I could pull a house down in 1st gear......if I could get enough traction! Laughing
    Post by DanTheVanMan Tue Jan 11, 2011 6:23 pm
    With the calculations I figured and the O.D. ratio being .65 at 70mph I should be between 1500- 1650 rpm's. And that works for me...... Also thinking if I shelf the 650 cfm and use the 500 my mileage will be ok as well. We'll see...... Question Will just have to play with it once I get it all together..... Cool
    Post by Digz Tue Jan 11, 2011 7:22 pm
    my 350/700r 4.11 has a sweet spot at 60mph about 2100 rpm , I made 13mpg on the Bakers trip and that was fighting some big wind on the way home. It even blew me off course and didnt meet back up with Gotavan Dan til 90 miles later about...hehehe
    Post by DanTheVanMan Wed Jan 12, 2011 6:00 am
    That's about what I'm getting in the Sportvan with the 230 & 2spd PG at about 50mph. I don't see taking any long trips at that speed anytime soon. If I run at 60mph the mileage drops to around 10mpg. And that would mean stopping every 150's miles to fill up.... Mad
    Post by DanTheVanMan Tue Jan 18, 2011 11:16 am
    Well just cracked the rear diff on the parts van and did not find the 3:90 gears I was told were in there but rather 3:73's. I guess this will put me at 1750 rpm's at 70mph rather than 2145rpm's.... Thinking this is a very good thing!!! Very Happy
    Post by Digz Tue Jan 18, 2011 2:05 pm
    Very good indeed ! I wouldn't mind running across a set of 3.73's myself.
      Current date/time is Tue May 07, 2024 12:42 am
