    anybody cutting up an early chev?
    Number of posts : 801
    anybody cutting up an early chev? Empty anybody cutting up an early chev?
    Post by panelmanrd Sat Jan 01, 2011 6:34 pm
    is there anybody out there cutting up a1st or 2nd gen chevy? looking for the vent door and
    surrounding frame to put one on the pass side also. I will be using an aftermarket heat/a/c def unit
    and will be making a plate to cover the exsiting hole left by the factory heater unit, I want to
    put the vent in that cover. any help would be great.
    Number of posts : 822
    Registration date : 2010-09-10
    anybody cutting up an early chev? Empty Re: anybody cutting up an early chev?
    Post by Roman Sat Jan 01, 2011 10:45 pm
    Hey dude, I'm doing the same thing. Quiet Ride Solutions in Stockton made me a cover out of ABS plastic for that hole with the screw holes already in it. They will have the pattern made up by Monday if you wanted just that piece. Do you already have your AC unit? You may have a problem finding a spot to put the vent door. I do not have my unit yet, but anticipate running into that problem.
    Good luck and let's keep in touch...
    Post by panelmanrd Sun Jan 02, 2011 7:58 pm
    planning using a vintage air genII supercooler as a front unit
    and a toyota previa minivan rear unit for the rear unit.
    making a plate to cover the original opening will not be
    that tough. gonna make mine from steel so welding on the
    vent door will be possible.
    Post by Roman Sun Jan 02, 2011 8:31 pm
    The issue is the AC unit will be mounted right in front of where the vent door would go. We don't have the luxury of having a big dash to hide stuff under.
    Post by panelmanrd Sun Jan 02, 2011 8:40 pm
    I`m gonna hang the unit centered under the dash, the drivers
    side will be almost against the wiper motor, will hang below the
    dash just above the tunnel I built.
    Post by Roman Sun Jan 02, 2011 9:21 pm
    Cool
      Current date/time is Wed May 08, 2024 11:48 am
