Starting on the windows
Re: Starting on the windows
Hi- where did u get the window rubber and the cost would be=??Thanx
VH hope you can make it to the Nat's. Very clean sportvan there and would like to see it up close
Rubbers not hard to find the local glass shops carry it by the roll. It's the front winshield we will have to make a seal for it.
G-man I really want to go to the Nat's already started prepping the wife for the trip!!
VH I know you still can get that rubber for the windshield
Vanish- Admin
- Number of posts : 5155
Yep the first one we Got from Brothers was a Perfect fit on a second gen Front Glass !!!!!!!
,,,Vanish,,,
MCMLXV
Is it from Brothers??
Vanish- Admin
Yep the First one I got from brothers..... I was trying to get on to fit my 1st Gen,,,,, Dident fit !!! but it did fit a secong gen windshield Perfect !!!!!!
,,,Vanish,,,
MCMLXV
Sweet thanks I will check it out!! There is a few to choose from do you remember whta year worked??
VH all second gens have problems there so don't feel to bad. Even my 2nd gen that was a fire dept van and kept inside all the time had rot there. I have seen much worst.
DanTheVanMan- Commissioner
- Number of posts : 7900
I see I'm not the only one with a 8-Track!
Yeah G-man I knew it was there and know it's all part of the fun!!
Dan you know you got to keep it real with the 8-track!!!
lfdcaptain- Number of posts : 46
Registration date : 2010-09-26
What would be the options for repairing/replacing that windshield rot? I have the same, and maybe worse, on my 68.
Are you planning on leaving the battery behind the seat? I moved mine beneath the floor once I discovered that the cover and tray from a parts van is pretty much a bolt on application using existing mounting holes.
You know haven't thought about it. Do you have pics of yours?
Yeah.... The frame and cross supports accept the tray and bolts out of a donor van. I'm lucky enough to live relatively close to V.V. member "64 chevy" who had a parts van for me to plunder. The compartment cover fits perfectly into that area by the side door and, if you cut carefully, the latch mechanism catches and seals nicely.
- Post n°19
Sweet I think I know where to get the door!!
