There was a great thread a few months ago about different approaches to insulating the interior walls. I did a search but haven't been able to find it, so if someone has a link I'd appreciate it.
Originally I was planning on using fiberglass batting but that thread pointed out how those bats retain moisture, eventually causing rust from the inside out. Not good, obviously. I will be doing my interior in the next few months so I need to refresh my memory on the alternatives.
Also, after I finish rewiring everything I was planning on using that spray foam insulation in all of the structural ribs and anywhere else I can insert the nozzle, to try and seal everything up as much as possible for sound deadening purposes. Any reason why this might not be a good idea?
