    2nd Gen V8 Clutch fan info.
    LiveWire64
    LiveWire64
    Number of posts : 244
    Registration date : 2009-03-17
    2nd Gen V8 Clutch fan info. Empty 2nd Gen V8 Clutch fan info.
    Post by LiveWire64 Wed Dec 08, 2010 10:31 pm
    Anyone know the clutch fan blade size that was used on the v8 engines in the 2nd gens? Also,what pressure radiator cap for the surge tank?
    Thanks for any help,Brad
    2nd Gen V8 Clutch fan info. Empty Re: 2nd Gen V8 Clutch fan info.
    Post by donivan65 Wed Dec 08, 2010 11:17 pm
    ,,,,,,,,,I would say the fan blade depends on the size of the shroud and the radiator hoses,,,,,,,,,you put the biggest one on that does not hit or rub. And I think the most common one is the 18" fan blade. And in case you are interested, a 6 cylinder shroud has a 19" opening,,,,,,,,,,
    2nd Gen V8 Clutch fan info. Empty fan size=?/
    Post by Twinpilot001 Thu Dec 09, 2010 8:34 am
    I will go out later 2 day & look as the van im building is the 2nd gen. V-8 model.
    LiveWire64
    LiveWire64
    Post by LiveWire64 Thu Dec 09, 2010 9:24 am
    Thanks guys! I was just curious. I will wait till I get a lil further along before I look for a fan.
    2nd Gen V8 Clutch fan info. Empty Fan & Raid/cap
    Post by Twinpilot001 Thu Dec 09, 2010 12:17 pm
    went out & measured mine- fan blade dia.= 15 inch -has a large type clutch also - I also have a fan blade with clutch thats a 16"=-a little-has same clutch on it - i do believe the 15 inch is the origional one .The pressure cap is a 14 lb. one - u can use also a 18 lb one yet the higher u go the higher the boiling point is raised. if ur @ sea level or near it id use the 14 lb one -Hope this helps,matt
    Post by donivan65 Thu Dec 09, 2010 2:03 pm
    So Twinpilot, do you have the stock 2nd Gen crossflow radiator and the V8 or 6 Cylinder type of shroud? These shrouds have a 19" opening for a 18" fan. I am thinking a person could improve on their airflow by filling that shroud opening with as much fan that will fit in there without rubbing. I think Livewire might be wanting to use a 6 cylinder shroud on his V8,,,,,,,,
    2nd Gen V8 Clutch fan info. Repai200
    Post by Twinpilot001 Fri Dec 10, 2010 6:08 am
    Yes , I do have the V-8 shroud. The 16 " fan I have is actually a little larger 1/4"?? maybe and as i am measuring it across for diameter. it could be larger yet as the blades are not across from each other. I bought this gen2 1967 van about 1 & 1/2 years back and was totally disassembled - was a roller yet in primar & all doors, seals & glass were removed. So=== Im dealing with a disassembly that i didnt do- so im slow at all the mods & rebuild. I did get the 383 motor installed , just before the ice & snows hit us here . Will test fire in april /' may next. Currently -looking for some electric , fold down seats for the front cab area. Also if Livewire has a 6 cyl shroud?? there is a guy on ebay that is selling a alunimum shroud that is made for the v-8 vans. I almost bought that one -yet didnt need it & its still available,matt
    Post by Twinpilot001 Fri Dec 10, 2010 6:11 am
    Also- from experiences with fans & shrouds - the larger the diameter that will fit in the shroud- with about 1/2 - 3/4 " clearance is best and the fan blades need to be almost to the end of the shroud- Gives the usage like a Venturi effect.
    richie61
    richie61
    Number of posts : 445
    Post by richie61 Fri Dec 10, 2010 6:43 am
    Livewire I have a brand new fan blade that was the wrong size for my first gen if you need one.
    2nd Gen V8 Clutch fan info. Fan_1110
    Post by donivan65 Fri Dec 10, 2010 9:39 am
    I think Livewire is inventing a system to put in his 1st Gen,,,,,,using the 2nd Gen crossflow radiator, surge tank and some sort of shroud, and a V8 engine, so we pretty much got him covered with all the different parts available to him,,,,,,,,,,,,,and if that is the picture of your fan blade, Rich, thats for a waterpump, not for a clutch.
    LiveWire64
    LiveWire64
    Post by LiveWire64 Sun Dec 12, 2010 9:34 am
    Denny Smith in IL has a 66 No-Door that he is putting a 454 in. He's using the cross-flow radiator & also the 6 cylinder shroud. Says it is a great fit with the 454.
    That is where I got my idea to use the 6 cylinder shroud.
    I will keep everyone posted. Brad
      Current date/time is Sun May 12, 2024 6:20 am
